Implemented | When using the line measurement options in the draw/measure panel. The measurement text goes behind the drawings and ... by MarlboroughDistrict_Council Occasional Contributor 3 2 | 3 | 2 | |
Under Consideration | HiJust a quick idea thats popped up due to user feedback. When using query parameters, if there is no record found th... by MarlboroughDistrict_Council Occasional Contributor 0 1 | 0 | 1 | |
Open | Broadly our users are struggling to make the maps they need using the drawing tools as they stand.Being able to edit ... by MattGrose New Contributor II 3 1 | 3 | 1 | |
Open | We often have requests of 'what properties have this on it'. This question could be answered in our previous web map... by TaupoDistrict_Council Occasional Contributor 0 1 | 0 | 1 | |
Open | There is a small inconsistency when measuring WGS84 coordinates depending on the method used.If using the Draw/Measur... by MarlboroughDistrict_Council Occasional Contributor 1 1 | 1 | 1 | |
Open | We've had comments from a few people that the default symbology used in the Select widget (blue outline with blue tra... by MarlboroughDistrict_Council Occasional Contributor 5 6 | 5 | 6 | |
Open | There are a couple of things that could be helpful to make text within drawings more readable.I've had requests from ... by TaupoDistrict_Council Occasional Contributor 7 9 | 7 | 9 | |
Open | The majority of the time our users add drawings into their maps they aren't interested in coordinates. Currently coo... by TaupoDistrict_Council Occasional Contributor 1 1 | 1 | 1 | |
Open | It would be useful if search results on a search query with multiple results could display in a search results window... by MarlboroughDistrict_Council Occasional Contributor 1 2 | 1 | 2 | |
Open | The select widget is very complicated for most of our users, too many clicks and often the select by attribute confus... by HellenSimpson New Contributor III 1 1 | 1 | 1 | |
Open | When configuring the Select widget within the LocalMaps map admin page, the layers are listed alphabetically. Sometim... by MarlboroughDistrict_Council Occasional Contributor 3 2 | 3 | 2 | |
Open | It would be easier for the user if in the Select widget, it either only displayed the layers that are actually turned... by MarlboroughDistrict_Council Occasional Contributor 1 1 | 1 | 1 | |
Open | When using the select widget in a map with many selectable layers, sometimes finding the layer with the selection can... by MarlboroughDistrict_Council Occasional Contributor 2 1 | 2 | 1 | |
Open | This would have to be one of our most requested features across the organisation. They would love to be able to simp... by NaomiBegg Occasional Contributor 5 5 | 5 | 5 | |
Open | It would be great if the save and share data options honoured layers added through the 'add data' tool.We are trying ... by NaomiBegg Occasional Contributor 3 2 | 3 | 2 |
Idea Submission Guidelines
