Dear all,
does anyone know if it is possible to save the .mxd map into PDF but with an A3 size?
Of course I know how to export the map as PDF but I was wondering whether it is possible to save it in a larger size. and if so, how it is possible.
I have arcMap 10.2.2
Thanks a lot,
F.
Solved! Go to Solution.
Check if this solution works for you
Printing at defined scale and paper size from ArcMap?
You need to change the page and print setting as desired > Go to Layout View > Export Map (PDF Format).
thanks a lot for your prompt reply. It seems it works.
Cheers,
F.
