Original User: zorbac
Wondering if there is a way to make the extent remain the same, even if the index layer extent varies. I'd like to do an atlas with one page for each bus route that intersects a study area. So, the index layer is based on the bus routes (each feature is equal to the envelope defined by a given route) For each page of the atlas I want the extent to remain unchanged (showing entire study area). Then I can use the "page definition query" settings to query the bus routes layer such that the corresponding bus route is shown on the map.
One solution is to create an index grid with a bunch of stacked polygons each equal to the same extent and populate an attribute with the route numbers. If I have to I'll do this, but I thought I would check if there is a better way. I believe this would be a nice enhancement. You could easily do atlases that compare multiple themes of data for the same area or temporal maps of the same area, etc...
