HELP WITH SYMBOLS
2724
6
09-22-2015 03:51 AM
francescarusso
New Contributor III
Hi, sorry for the basic question. I hope it is the right place where to ask. I have some points layer for KP (kilometre point) for cable route. I need to have the proper symbol in the legend but i cannot find in the symbols list. Do you have any idea where I can get him?Many thanks.
DanPatterson_Retired
Is it one that is supposed to exist? do you have a sample?
francescarusso
New Contributor III
Hi Dan,
thank you for answering. I have attached an example of what I am looking for.
Thanks once more.
WesMiller
Regular Contributor III
If you know what the symbol is called you could search for it, at the top of the symbol selector window there is a place to search. Where did you get the symbol you have, if it's from another map you could use the other map to discover the symbols source. The are also options to create your own symbols, if your interested in doing a little extra to get the symbology your after.
francescarusso
New Contributor III
Hi I tried to search for the name of the symbol but I couldn't find it at all and the map I took it from is a pdf so I have no clue what is the source. Is it easy to create my own one?
Thank you for your answer
WesMiller
I've created a few, it's not to hard, check out this site to help you get started About creating new symbols—Help | ArcGIS for Desktop
francescarusso
New Contributor III
Cheers,, much appreciated.
