How do I access mbtiles format inside ArcMap/ArcEngine
10131
09-04-2011 01:46 AM
RegunathanUmapathy
I have come across a website namely mapbox.com. There are quite a lot of maps available in mbtile format. For example there exists a Iraqi map available via http://mapbox.com/#/tileset/iraq as a mbtiles format. I can download the file, that is not the problem after that what do I need to do If I want to display in ArcMAP or ArcGIS engine? I found a stand alone view but it didn't help me much. I want add mbtiles as a layer either inside the ArcMap or in the ArcEngine. How can I achive this? thanks in advance.
GastonIzaguirre
Hi Regunathan, I'm facing the same problem you've described.
Have you achieved any solution in all this time?
I have a lot of raster tiles, with the associated mbtile file, but I can't open them as a layer Arcmap.
Any help would be appreciated.
Regards.
DuncanHornby
MVP Notable Contributor
Looks like even at 10.6 neither ArcMap or Pro can open mbtile formats, but QGIS does!
