how to use Cyrillic in an attribute table in ArcMap 10.3.1
4847
02-08-2016 02:04 PM
MK5
New Contributor II
I am creating a new attribute for an existing shapefile in ArcMap 10.3.1, which will contain a Russian place name (in Cyrillic alphabet).
While editing, I can enter information in Cyrillic, but as soon as I save the edits, the text both in the Attribute Table and Map converts to "??????????"
None of the fixes I have found online have worked. These have included:
- Checking that I have Cyrillic fonts enabled on my computer (Windows 7). I regularly type and read in Cyrillic in multiple applications. In ArcMap, Cyrillic is not recognized whether I copy and paste Cyrillic text, or enter it using a Cyrillic keyboard.
- I have tried changing the font used in tables in ArcMap (per this old discussion - Cyrillic Language Problem ). This did not help
- I tried using markup in the Attribute table, per this discussion - http://desktop.arcgis.com/en/arcmap/latest/map/publish-map-services/drawing-behaviors-of-the-map-ser...
I appreciate any tips you can give me.
DanPatterson_Retired
for shapefiles, you need to have a codepage file (*.cpg) Shapefile file extensions—Help | ArcGIS for Desktop
which specifies which the codepage to use
I don't know if these apply to 10.3.1, but I will throw them out anyway
21106 - Read and write shapefile and dBASE files encoded in various code pages
Setting codepages in shapefiles to display in ArcMap 10 – A saga | Mapoholic
and this link... which you may be able to digest more than I do
Esri Support - Search Results
MK5
New Contributor II
Thanks for pointing me towards the .cpg file. I found an already-existing cpg file, opened it in a text editor, and manually edited the contents. I tried a couple of the charsets listed on this page: Character Sets
It looks like UNICODE or UTF-8 is working for my purposes.
Then saved the cpg file with my shapefile's name. It looks like it's working now.
If there's a more automated way to make this change, I'd be interested to hear it.
Distractions distractions.
A demo... using a sample *.cpg file.  only if you have a bunch of shapefiles in the same folder.
Test, and change.  Written verbosely so you get the drive
>>> import arcpy
>>> folder = r"F:\A2_in_progress\NearDemo\Shape_test"
>>> arcpy.env.workspace = folder
>>> FCs = arcpy.ListFeatureClasses() #see the help for more options
>>> for fc in FCs:
...  print("Shapefile : {}".format(fc))
Shapefile : Polyline.shp
Shapefile : RandomPnts.shp
>>> cpg = folder + "\\demo.cpg"
>>> for fc in FCs:
...  out_name = fc[:-4] + ".cpg"
...  arcpy.Copy_management(cpg, folder + "\\" + out_name)
<Result 'F:\\A2_in_progress\\NearDemo\\Shape_test\\Polyline.cpg'>
<Result 'F:\\A2_in_progress\\NearDemo\\Shape_test\\RandomPnts.cpg'>
MK5
New Contributor II
Thanks, Dan!
