Maplex Not Functional although licensed as 10.1
1353
14
08-17-2011 06:46 AM
RichardBaker
New Contributor III
Maplex does not function in 10.1 even though authorized and licensed. It seems to be installed but all tools grayed out.
JoshWhite
Regular Contributor III
I too have the issue with everything Maplex being grayed out. I didn't enter an authorization code or check that I wanted an evaluation but I was under the impression it was being included in 10.1 for all license levels.  Perhaps I was misinformed.  I tried enabling Maplex in 10.0 and it wouldn't let me do that at all so something has changed with 10.1
Josh White, AICP
Principal Planner
City of Arkansas City
LorenMuehlius
New Contributor III
Josh,
I did send it as a bug (AGISDTEX10.1-000009, this is under the arcGIS extensions bug list) and the esri folks have fixed it for future betas.
LoralynClark
New Contributor II
It is working for me. I did enter an authorization code and checked off that I wanted Maplex as part of the evaluation. I checked the Maplex extention, turned on the labeling toolbar and chose the "Use Maplex Label Engine" and all appears to be working fine. I am using Windows 7.
LeslieZolman1
New Contributor III
I just installed ArcMap Advanced and entered authorization codes for all the extensions.  However, Maplex was not listed in the extensions so I was unable to authorize it.  How do I get Maplex authorized and working??
LorenMuehlius
New Contributor III
Leslie,
If you have Beta 2 of 10.1, I found that you can just go to the labeling toolbar, click the Labeling button and then select, Use Maplex Engine. I guess they took Maplex out of the Extensions since it now works on all the products.
You can make Maplex the label engine by default by going to Customize|ArcMap Options, click the Data View tab and then select Maplex Label Engine under Label Engine.
Hope that helps.
