Simple scripting help
3256
8
10-12-2014 06:23 PM
stuartcassin1
New Contributor II
to assist with symbology, I'm trying to populate a column with alternate 1 & 0 so I can filter and symbolise alternate records. I need a simple method to auto complete a table of approx 5000 records. Can anyone help?
RobertScheitlin__GISP
Stuart,
  Timothy's code is the complete copy and paste code that you need to put in the field calculator.
The only difference is that your field would be:
[FID] Mod 2
Just Copy and Paste the above line in the Field Calculator window in ArcMap.
DanPatterson_Retired
python processor, use the FID field or any other sequential field
>>> from math import fmod
>>> for i in range(20):
...  if fmod(i,2) == 0:
...      print 0
...  else:
...          print 1
.......etc
python parser, enable the code block this is the function to use and in the expression box you could use ones_zeros(!FID!) (ps... haven't tried the code block but the above python syntax is the key
def ones_zeros(your_field):
  if fmod(your_field,2) == 0:  print 0
  else:  print 1
stuartcassin1
New Contributor II
Thanks for the suggestion Dan,
Unfortunately that didn't work. I mistakenly forgot to mention I'm using ArcGIS Basic 9.3.1 on an enterprise licence and I'm pretty sure the PythonWin Application hasn't been installed. Is there a way I can do this via the field calculator or the command line window?
I'm afraid my scripting / coding skills are pretty much zero.
TimothyHales
Esri Notable Contributor
You should be able to just use the Mod operator in the Field Calculator:
[ObjectID] Mod 2
stuartcassin1
New Contributor II
Thanks Timothy,
Any chance you could supply the full script for the Field calculator (9.3.1)? I have no idea what the Mod operator is.
Sorry - scripting dummy here.
yiqi
New Contributor II
I think it is just "mod", i mean, you can input "i=5 mod 2" which will make i=1. So, "[ObjectID] Mod 2", as Hales mentioned above, is what you can use directly.
stuartcassin1
New Contributor II
Just some additional info for this question:
I'm using ArcGIS 9.3.1 Basic
I only have access to the command line window or the field calculator. All other scripting options are unavailable
I have pretty much no skills in scripting so really am looking for the complete answer (cut & paste??)
The only sequential field in the attribute table is the FID column.
Hopefully someone can help me with an appropriate code. Thanks
Stuart,
[FID] Mod 2
stuartcassin1
New Contributor II
Thanks guys.
Worked perfectly.
