Variable Depth Masking Issues
1984
06-23-2015 07:53 AM
GabeBissonette
I have an ArcMap 10.2 *.mxd that uses variable depth masking.  I had originally set up the *.mxd to mask a number of layers.  However, to minimize the export time I unchecked some of the layers that were being masked.  However, when I refresh the map the text in the lower left that describes what ArcMap is doing still indicates that it is masking the layers I have unchecked.  It seems to remember the original settings and won't recognize that I have unchecked these layers.  Any ideas?
Thanks
Tags (1)
