"ArcGIS Pro and Geospatial Workflows in Mining" Webinar
933
05-27-2022 03:53 PM
SarahPowell1
We hope you enjoyed the "ArcGIS Pro and Geospatial Workflows in Mining" webinar, that was on June 1, 2022.
Please see the video recording of the webinar.
For further information, please contact the following Esri staff:
- Darin Bryce: dbryce@esri.com
- Scott Noulis: snoulis@esri.com
Select questions and answers coming soon
  • Is there an export to MXD feature in ArcGIS Pro?
    • You can certainly import but no other way around
  • In ArcMap the online selection of data is much greater than what is available in ArcGIS Pro, why is that?
    • Let's connect so we can go over how to expose all the online data options.
  • ArcGIS Pro v3.0 is coming soon. In Beta testing, we have seen that all vendor add-ins (Datamine, Seequent, DataEast etc) will not be compatible with AGP 3.0 because of an updated requirement for .NET Framework updates. Is the MUG or Esri Mining Team reaching out to these vendors to motivate them to update sooner than later?
    • Yes, we are in contact with our various partners about updating these add-ins.
  • Can we have a free license for 1 month?
    • DEEP, an evaluation of ArcGIS Pro is available through the Esri website, esri.com.
  • Is Discover plugin incorporated into the software or does it require an extra license?
    • The Discover plug-in is a separate license that can be purchased directly from Datamine. Esri is not a reseller of the plug-in.
  • I see quite a lot of similarities with ArcMap, are there plans to reduce the products by possibly merging ArcMap functionalities into Pro?
    • ArcGIS Pro is replacing ArcMAP. All key functions & tools have been migrated to Pro already. ArcMAP will eventually be decommissioned.
  • How is the application performance when working with 3D data?
  • Our users are becoming lazier with growing tech advances, are there any plans to reduce the number of clicks for some of the processes. I am thinking along machine learning capabilities that can mimic user patterns and behaviors.
    • Pro can take advantage of ML tools & the toolbar can be customized to only show those tools the user most often accesses. There is also a "task" function where a workflow can be reduced to s a specific set of steps.
  • Are there any plans to move away from desktop applications to a web-based application?
    • Both the local client application ArcGIS Pro and the web version ArcGIS Online will be offered moving forward, not at the current time.Ar
  • Can ArcGIS Pro work offline or must you be online first to use it?
    • You can take ArCGIS Pro offline.
Thank you for your time and attention. Be on the lookout for additional mining webinars.
Sincerely,
Esri Mining Team
