ArcGIS Pro 2.5: How to overwrite outputs of geoprocessing tools when run in a model builder?
3943
7
05-08-2020 09:22 AM
JamalNUMAN
Legendary Contributor
Despite the fact that “Allow geoprocessing tools to overwrite existing datasets” option is checked, outputs appear not be overwritten when working with model builder.
What could be the issue here?
Jamal Numan
oliviersouligno
Hi Jamal,
Wow, I have exactly the same issue, I am happy to see that I am not the only one to experiment this .
Did you find a solution ?
JamalNUMAN
Hi Olivier,
I’m still waiting for some feedback from esri experts on this issue. Not sure if some of them has already explored this problem
Jamal Numan
JoeBorgione
I don't write any models, but you should be able to set an environment that allows you to over write existing data.
Take a look here: Geoprocessing environment settings—ArcGIS Pro | Documentation
That should just about do it....
JamalNUMAN
I couldn’t find myself an option that allows overwriting except the one that appears in screenshots of my first post.
Jamal Numan
JamalNUMAN
For example, if the cell size the in the “Euclidian Distance” is changed, then the outputs are not replaced, instead new raster are created!
Is there a way to overwrite such that the number of outputs are kept 5 for my model?
Jamal Numan
AZendel
Occasional Contributor III
If I'm interpreting these posts correctly, there is no way to specify that a particular/individual geoprocessing model should overwrite its outputs. The only option is to set this in the Pro options tab as shown in the first post. Is this still the case? I'm calling a lot of geoprocessing models from ArcPy and I want to allow some of the models to overwrite existing outputs. This setting in the Pro user interface is likely ignored when running a completely standalone ArcPy script.
Please confirm when you can. And ESRI, if you're reading this, please allow this option to be set within individual models.
curtvprice
MVP Esteemed Contributor
When calling your model from arcpy, arcpy.env.overwriteOutput should be set to True. Is this not working? Often in the desktop apps it is common for a layer to not easily release file locks (regardless of overwrite setting), lots of bug fixes of that through the years.
When running standalone outside of the desktop app, there aren't data layers in the interface (just in memory when created) so these problems are less likely - IF you make sure the environment overwriteOutput is set to True in your code.
