I have created a model that clips, projects and then writes a raster to a floating point output. I would like to be able to insert a true/false or if/then else type switch before running the float tool to enable the final out put to be selected by the user, that is, stopping it before the float tool if desired. I don't use Python. Is there a way to branch the model to either run the float tool or not?
