Hello,
I'm trying to build a model that can take any feature class loaded in and then have the field names available as a user-selected variable which will then power a bunch of geoprocessing tools. How do I set this up so that I can choose the dataset and then the appropriate field name before pressing run on the model?
Thanks!
Luke
Yes you can, see instructions here: Field filter—Help | ArcGIS for Desktop
Hi Xander,
Thanks for your help. I'm having trouble with it though - doesn't a field filter decide what type of field can be allowed rather than letting you specify actual field names? I want a tool where you specify the dataset that needs buffering and then specify the relevant field name that contains the information that will drive the buffer sql expression. I can't see how to do this using the help page you've posted?
I'd really appreciate your thoughts as it's driving me mad!
Luke
EDIT: I've found a way to do it using the 'Get Field Value' Utility... but this only accepts tables as inputs, not feature classes. How can I extract field values from feature classes?
In fact the Get Field Value—Help | ArcGIS for Desktop tool (although it mentions "tables" in the help) also allows the use of featureclasses.
This should work with any tool that takes a layer/feature class/table/table view and a field as input if you mark the dataset input and the field input as input parameters, not just Get Field Value.
I have the following model set up:
but whenever I try to change the input feature class my model won't run because of the following errors:
How do I set up this tool so that it accepts feature classes? Am I doing something obviously wrong here??
Thanks!
what is the OpenSpace parameter defined as? The only reference I could fine had something to do with cityengine. The error is saying that that parameter has to be of a particular type and featureclass etc isn't one of them
I seem to have fixed it by using the 'Make Feature Layer' tool as an intermediary - the field value tool is happy with a feature layer, just not a feature class.
Select Layer by Attribute requires an input feature layer, if you want to use that tool you need to make a layer from your input in case it is a feature class.
