How to export whole project for use in another PC (sharing)?
688
05-23-2019 06:59 AM
GotreGotrewyan
New Contributor II
project package‌ arcscene arcglobe export‌asset package‌#
I have a Database and toolbox in 3D(ArcScene) which I want to share it to another pc and run the model there.
How can I do that? I'm currently using Arcgis Desktop 10.6
curtvprice
MVP Esteemed Contributor
My suggestion:
Make sure relative paths are set (sxd properties), save the sxd, exit ArcScene and zip up the sxd, toolboxes, and data that is used. Copy the zip file and unzip on computer #2.
DuncanHornby
MVP Notable Contributor
If it where an ArcMap document you could have used a MapPackage to pack everything up and share. I believe ArcScene does not support MapPackages (I might be wrong?). But it does support Layer Packages. Explore the help file and search for "creating a layer package".
GotreGotrewyan
New Contributor II
Yes I'm aware of MapPackage but I work in arcsene. Also I'm not sure.but I think map package does not include model and tools!
curtvprice
My suggestion:
