Hello @AnonymousUser23
Thank you for reaching out to us with your issues. I have a couple of questions for you.
- Is your graphic rendering mode static?
- What version of the sdk are you using? Is it the 100.x series?
The reason I ask those is because from the first video, it appears that the rendering issue is related to static rendering. We've seen refresh issues with static rendering mode especially in 3D. If you can share your data, we could take a look to see exactly what can be done to improve on it.
If you are using static rendering, is it possible to change it to dymamic and see if it helps?
The terrain draping issue you mentioned has been fixed in 200.x series. That is why I was asking the version question. Are you able to try it out with 200.x if you are on 100.x? If you are on 200.x, then again, sharing the data would help us look into it to see how we can improve on it.
Please feel free to reach out to us if you have more questions.
Regards,
Koushik
