Using ArcGIS Runtime for .NET 100.0 and WPF. I have a geometry created using the sketch editor ...
_traceGeometry = await Mapview.SketchEditor.StartAsync(SketchCreationMode.Polyline, true);
Then later I want to create a feature using this geometry. However, the feature class has z values. So when I try to save it via ...
await table.AddFeaturesAsync(features);
I get an exception: "The shape must have a Z value."
My question is how can I add z values to this geometry? Do I need to recreate a new geometry using PolylineBuilder and adding a z-value for each point?
Initially all points can (and should) have 0 for a z-value, but eventually, we will run a calculation that adds z-values based on underlying elevation.
Alternatively, will the sketch editor create a z-enabled geometry if there is underlying elevation data included as a map layer?
