Hello,
I am trying to test AR Toolkit Samples for MAUI from GitHub (https://github.com/Esri/arcgis-maps-sdk-dotnet-toolkit/tree/main/src), but after opening the solution "Esri.ArcGISRuntime.ARToolkit.sln" and running "ARToolkit.Samples.Maui" on my Android device (API 29), I keep getting this error message:
Severity Code Description Project File Line Suppression State
Error AMM0000
Attribute application@appComponentFactory value=(androidx.core.app.CoreComponentFactory) from AndroidManifest.xml:24:18-86
is also present at AndroidManifest.xml:22:18-91 value=(android.support.v4.app.CoreComponentFactory).
Suggestion: add 'tools:replace="android:appComponentFactory"' to <application> element at AndroidManifest.xml:15:3-37:17 to override.
ARToolkit.Samples.Maui D:\dotNET_Arcgis\arcgis-maps-sdk-dotnet-toolkit-main\src\ARSamples\ARToolkit.Samples.Maui\obj\Debug\net6.0-android\AndroidManifest.xml 24
The "Esri.ArcGISRuntime.Toolkit.sln" is working fine, so the problem probably has to do something with the AR itself. I am using the ArcGIS Maps SKD for .NET v200.0 and also the newest version of the Toolkit.
Thanks in advance for any help, I asume that it is just a beginner problem 🙂
FM
