I have a strange behaviour in my two test applications, both based on ArcGIS Runtime 100.2.
Both worked fine for many hours of developing, now I got an exception in both, even I did not change anything in one of these apps.
Both a very small and focused and have the same startup:
public MainWindow()
InitializeComponent();
InitializeMap();
private async void InitializeMap()
Map map = new Map(Basemap.CreateTopographicVector());
FeatureLayer featureLayer = new FeatureLayer(new Uri("http://sampleserver6.arcgisonline.com/arcgis/rest/services/Wildfire/FeatureServer/2"));
await featureLayer.LoadAsync();
map.OperationalLayers.Add(featureLayer);
MyMapView.Map = map;
Both are now crashing in the same line 13, where the LoadAsync should be executed.
System.Net.Http.HttpRequestException occurred
HResult=0x80131500
Message=An error occurred while sending the request.
Source=mscorlib
StackTrace:
at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)
at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd(Task task)
at Esri.ArcGISRuntime.Internal.RequestRequiredHandler.<IssueRequestAndRespond>d__15.MoveNext()
at System.Runtime.CompilerServices.TaskAwaiter.GetResult()
at CustomGPSProvider.MainWindow.<InitializeMap>d__1.MoveNext() in C:\Users\mag\Documents\Visual Studio 2017\Projects\CustomGPSProvider\CustomGPSProvider\MainWindow.xaml.cs:line 37
Inner Exception 1:
WebException: The request was aborted: The request was canceled.
Inner Exception 2:
NullReferenceException: Object reference not set to an instance of an object.
The StackTrace for the Inner Exception 2 is:
at System.Net.HttpWebRequest.CheckCacheUpdateOnResponse()
at System.Net.HttpWebRequest.CheckResubmitForCache(Exception& e)
at System.Net.HttpWebRequest.DoSubmitRequestProcessing(Exception& exception)
at System.Net.HttpWebRequest.ProcessResponse()
at System.Net.HttpWebRequest.SetResponse(CoreResponseData coreResponseData)
I have no idea what's wrong.
Any ideas?
Max
