This is very odd. Mind you nothing has changed in this in years.
But I was noticing how it showed the region strings in the content. This is how State is setup in the view, and the user just picks a value from the dropdown
<ComboBox Grid.Column="1" SelectedIndex="0" SelectedValue="{Binding State}">
<ComboBox.Items>
<ComboBoxItem Content="PA" />
<ComboBoxItem Content="WV" />
<ComboBoxItem Content="KY" />
</ComboBox.Items>
</ComboBox>
But what I decided to do was make a change, because the string shown in my first post seemed odd. Previously, I just had State bound directly, but I changed it to
State = ((ComboBoxItem)State).Content.ToString()
After this change I am again getting valid results without needing the additional input.
Based on the timing of the issue appearing and the fact that there was an April update to the geocoding service I am still going to put that update as the cause. But what it seems is that prior to the change the string
System.Windows.Controls.ComboBoxItem: PA
was parsed as PA. But after the update that was no longer the case. I will not argue that parsing the above string to 'PA' should have been expected behavior. Simply that evidence points to that was what was occurring. After making the change in the code things seem to be working as expeected.
Thanks for the help, putting everything down and also looking at what happened with the query (and some Fiddler) pointed me where I needed to find the solution
-Joe
-Joe
