Hi all!
Does any one know if it is possible to sync geodatabase using service that requires autentication (token)?
Generate geodatabase works fine with token, but when I try to sync my geodatabase back to server, it fails.
I am using a pregenerated long term token.
In fiddler I can se this response {"error":{"code":499,"message":"Token Required","details":[]}} after 401 challange,
I don't se any token in the post request, so I belive the problem is in my code or a bug in the .NET runtime.
My code:
var taskParameters = new SyncGeodatabaseParameters()
RollbackOnFailure = false,
SyncDirection = Esri.ArcGISRuntime.Tasks.Offline.SyncDirection.Upload
var gdbTask = new GeodatabaseSyncTask(uri);
gdbTask.Token = token; // pregenerated longterm token
GenerateGeodatabaseResult r = await gdbTask.SyncGeodatabaseAsync(taskParameters, gdb, syncCompleteCallback, null, new TimeSpan(0, 0, 3), progress, cancelToken);
I have tried this in both runtime 10.2.5 & 10.2.6. (ArcGIS Server 10.22)
