I've used this demo
arcgis-runtime-demos-dotnet/src/TurnByTurn at master · Esri/arcgis-runtime-demos-dotnet · GitHub
i modified it to work locally, with VPTK as basemap and local locators and Network Dataset,
all work well except 1 thing,
how do i change the language of the network result to be in hebrew
var parameters = await task.CreateDefaultParametersAsync().ConfigureAwait(false);
parameters.SetStops(stopList);
parameters.ReturnStops = true;
parameters.ReturnDirections = true;
parameters.DirectionsLanguage = "he";
parameters.RouteShapeType = RouteShapeType.TrueShapeWithMeasures;
parameters.OutputSpatialReference = SpatialReferences.Wgs84;
parameters.DirectionsDistanceUnits = Esri.ArcGISRuntime.UnitSystem.Metric;
parameters.StartTime = DateTime.UtcNow;
try to use DirectionsLanguage with the values "he" or "he-IL" didnt work for me.
i have the resources.xml file already localized to hebrew and tried to put it inside
C:\Program Files (x86)\ArcGIS\Desktop10.5\NetworkAnalyst\Directions\he
do i need to put in different place?
it supposed to be offline navigation app, the client will not have ArcMap install on their local machine
Shahar.
