Getting 'The call is ambiguous between the following methods' when using SaveAsAsync in Esri.ArcGISRuntime.Mapping
716
08-15-2017 02:17 PM
RobertAbell
I am using code in the documentation for the ArcGIS Runtime SDK for .NET (WPF) and am getting 'The call is ambiguous between the following methods or properties: 'Map.SaveAsAsync(ArcGISPortal, PortalFolder, string, string, IEneumerable<String>,Uri,bool' and 'Map.SaveAsAsync(ArcGISPortal, PortalFolder, string, string, IEneumerable<String>,RuntimeImage,bool''
When looking at the Map class the Uri method is marked as 'Obsolete' and says to use the 'RuntimeImage' method instead but I am not sure how to force the code to use the correct method.
Not sure what other details are needed to help define my question.
NagmaYasmin
Occasional Contributor III
Hi Robert,
You could use the Map.SaveAsync() method using a reference of RuntimeImage as below:
RuntimeImage img = null;
await _map.SaveAsAsync(agsOnline, null, title, description, tags, img);
If you have downloaded the samples, look at this sample named " AuthodEditSaveMap" , it has the implementation of this method. Hope that helps.
Nagma
NagmaYasmin
Hi Robert,
Nagma
RobertAbell
Thanks so much Nagma!  This worked perfectly and makes sense.  Appreciate the quick reply. 🙂
