I'm working on an iOS application and I'm using the (Esri.ArcGISRuntime 100.15.1) Nuget Package. Just like addProxyRule(rule) method in JavaScript, is there any method for Xamarin iOS to set the Proxy. I am using https://xyz.com/proxy.ashx Proxy script.
If there is no method for Xamarin what is the other way to set my proxy script?
Thank you in advance.
Are you referring to this proxy? https://github.com/Esri/resource-proxy/
If so, those proxies were mainly meant for webapps, not native apps. Can you share some details around why the proxy is needed in your xamarin app?
