I followed the instruction except those for deployment because for the first try it is enough for me to run it on a developer machine. This machine is equiped with VS 2015, I can add the nuggets as shown in the instructions.
When I run the code for "Run geoprocessing servcies" I get the message "The application is licenced for developer use only". After that message the RuntimeLocalServer.exe(32bit) disapears from the process list in the Task manager and a dump report is generated (see attached).
The execution of the code from "Run map image layer services" works fine, I recieve an URL and I can work with the Package.
For the geoprocessing I use a selfmade package - but it also failes with the "message-in-a-bottle.gpk", "clip-features.gpk", "contour.gpk", "LineOfSight.gpk" and "simple-buffer.gpk" taken from previous samples from Runtime SDK.
What am I doing wrong?
Thank you in advance for your ideas!
Christian
