LocalLocatorTask "one or more of the locator's properties is invalid"
1405
11
08-17-2017 11:03 AM
EdwardBlair
Am trying to create a LocalLocatorTask using a composite locator.  This works when I use it in ArcMap.   But when providing the .loc file to Runtime I get the error "One or more of  the locator's properties is invalid".   Are there Runtime-specific requirements for locators?  Code is below.  Any insights would be much appreciated.
Ed
private void SetupLocator()
try
string locatorPath = @"C:\GISData\Data\Snapshot\CompositeStreetLocator.loc";
_locatorTask = new Esri.ArcGISRuntime.Tasks.Geocoding.LocalLocatorTask(locatorPath);
catch (Exception ex)
this.Log.LogException(ex);
NagmaYasmin
Hi Radihika,
You could set the OutputSpatialReference of the GeocodeParameters to "SpatialReferences.Wgs84" to get the lat/long coordinates
GeocodeParameters gcParams = new GeocodeParameters();
gcParams.OutputSpatialReference = SpatialReferences.Wgs84;
IReadOnlyList<GeocodeResult> results = await localLocatorTask.GeocodeAsync("address", gcParams);
Debug.WriteLine("Latitude: " + results[0].InputLocation.Y + " Longitude: " + results[0].InputLocation.X);
Hope that helps.
Nagma
MariusRocher1
Ed
Fancy running into you here on the forum.    I suspect your environment was much like mine.
Here is what I found:
1. I created the Runtime content and locator (composite locator) using ArcGIS 10.5.
2. I used a runtime application built on 10.2.7 to access the locator much like your posted code does.
3. Got the error you are reporting.
4. I created the Runtime content and locator (composite locator) using ArcGIS 10.2.2.
5. Tried this locator with the same 10.2.7 based app and it works.
There appears to be a compatibility issue that I did not expect and perhaps missed in Esri documentation.
Perhaps Esri folks can shed light on this?
Regards
Marius
