[EDIT2] Esri tech support has logged BUG-000118762 in reference to this issue
[EDIT] Visual studio project added, which demonstrates issue
This behavior is with .NET Runtime 100.4
When querying a service feature table using a complex geometry, the QueryFeatureAsync() method throws an error (shared below) which indicates that the Uri is too long. I can regularly run simpler geometries through this code, so my assumption is that there is a problem with the volume of information being handled when this method URL encodes and/or attempts to post to the server.
The query parameters sent into the query is straightforward, consisting of the geometry and a spatial relationship of intersects. As I mentioned, the geometry is a complex one. Something like a 244 part polygon consisting of about 24,500 points. I've attached the JSON for this polygon below as buffers.json.
You can point the query with that geometry at this endpoint:
Layer: Taxlots (ID: 😎
As an aside, this issue sounds alot like a post on stack overflow related to System.Net.Http.HttpClient. I don't see anything actionable in there since the exception is being thrown out of an Esri method.
Here is the error:
HResult: -2146233033
Message: "Invalid URI: The Uri string is too long."
Source: "Esri.ArcGISRuntime"
StackTrace:
at Esri.ArcGISRuntime.ArcGISException.HandleCoreError(CoreError error, Boolean throwException)
at RuntimeCoreNet.GeneratedWrappers.Interop.CheckError(IntPtr errorHandle, Boolean throwOnFailure, GCHandle wrapperHandle)
at RuntimeCoreNet.GeneratedWrappers.CoreTask.Get()
at Esri.ArcGISRuntime.Internal.CoreTaskExtensions.TaskCompletedCallbackHandler`1.OnCompleted(Object sender, EventArgs e)
--- End of stack trace from previous location where exception was thrown ---
at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
at Esri.ArcGISRuntime.Internal.CoreTaskExtensions.TaskCompletedCallbackHandler`1.<CreateInternal>d__7.MoveNext()
at Esri.ArcGISRuntime.Data.ServiceFeatureTable.<QueryFeaturesInternal>d__45.MoveNext()
at System.Runtime.CompilerServices.TaskAwaiter`1.GetResult()
at MapWorks.LayerSelection.SelectableItem.<ExecuteQuery>d__35.MoveNext() in C:\GitHub\MapWorks\MapWorks\LayerSelection.xaml.cs:line 1285
Thanks for your assitance!
