Which local service layer we can use to load a sceneLayer
1521
11
08-25-2017 01:52 AM
ManelKEDDAR
New Contributor III
hello ;
for displaying featureLayers as feature Tables we use ServiceFeatureTable , i'm trying to edit a sceneLayer with creating 3D geometry but i don't know how to load the table for example when i work with feature layers and 2D Features  i use the following code :
ar featureTableUri = new System.Uri(" URI");
var table = new ServiceFeatureTable(featureTableUri);
await table.LoadAsync();
var layer = new FeatureLayer(table);
MyMapView.Map = new Map();
MyMapView.Map.OperationalLayers.Add(layer);
var builder = new PolygonBuilder(SpatialReference.Create(2154));
var partOne = new Part(builder.SpatialReference);
//add a line segment going from (0,0) to (0,7)
partOne.Add(new Esri.ArcGISRuntime.Geometry.LineSegment(0,1670.82, 1500, 1400));
//add an other segment from (0,7) to (3,6)
partOne.Add(new Esri.ArcGISRuntime.Geometry.LineSegment(new MapPoint(1500,1400), new MapPoint(1300, 1200)));
builder.AddPart(partOne);
Esri.ArcGISRuntime.Geometry.Polygon polyGeom = builder.ToGeometry();
var description = "description";
var attributes = new Dictionary<string, object>();
attributes.Add("SHAPE", polyGeom);
if (table.LoadStatus == Esri.ArcGISRuntime.LoadStatus.Loaded)
var template = table.FeatureTemplates.FirstOrDefault() ?? table.FeatureTypes.FirstOrDefault(t => t.Templates.Any())?.Templates?.FirstOrDefault();
// var couchesCarte = MyMapView.Map.OperationalLayers[0] as FeatureLayer;
// var selectedFeatures = await couchesCarte.GetSelectedFeaturesAsync();
var feature = table.CreateFeature(template,polyGeom);
await table.AddFeatureAsync(feature);
// push this update (apply edits) to the feature service
IReadOnlyList<EditResult> editResults = await table.ApplyEditsAsync();
// check the results for errors
foreach (var r in editResults)
if (r.CompletedWithErrors)
Console.WriteLine("Edit to Object '" + r.ObjectId + "' failed: " + r.Error.Message);
this code works perfectly , now i need to know what i should use in case that i have 3D features and a sceneLayers i have 3DFeature class with multipatch geometry and i have created with my own code a 3D cone (3D feature )(3D geometry ) and i have to add this geometry to my feature class till now i 'm using (.slpk) to load the URI of my sceneLayer i need to know how to edit my sceneLayer with creating a new 3D feature ?
here's how i load my sceneLayer
Uri sceneURI =new Uri(@"C:\Users\mkeddar\Documents\scene\scene3D.slpk");
ArcGISSceneLayer sceneLayer = new ArcGISSceneLayer(sceneURI);
MySceneView.Scene.OperationalLayers.Add(sceneLayer);
await sceneLayer.LoadAsync();
any one can show me how to do that
thanks
Michael BranscombNagma YasminJennifer NeryMorten NielsenDan Patterson
Tags (1)
ManelKEDDAR
New Contributor III
Yes i'm referring to Engine
ManelKEDDAR
New Contributor III
