I also faced the same problem with creating the first map, Based Layer Streets and then a Data Layer. One time it did open up and when I tried it later following the exact same actions it didn't.
When you first add a Data Layer, open the Attribute Table and then add the Based Layer Streets, the problem never came up and I can work just fine. I don't know if this is relevant for you, but for me it works.
