Select Multiple Polygons and then Merging them
4085
6
04-12-2015 08:34 PM
bobbycorpuz
New Contributor II
Good day everyone, can somebody help me with my problem? I want to Select Multiple Polygons from the same layer and merging it after the selection (programatically). I am using arcmap 10.1 and vba as my coding environment. Tnx in advance for your help.
Tags (1)
DanPatterson_Retired
Programmatically...using vba? are you working in Desktop or elsewhere?
bobbycorpuz
New Contributor II
yes sir Dan Patterson​... i am working with Desktop.
bobbycorpuz
New Contributor II
for example sir. i want to merge those highlighted parcels programmatically. Can you please send me some vba codes?
And before that i use this code to highlight them manually.
HIGHLIGHTED CODE:
Private Sub UIToolControl1_MouseDown(ByVal button As Long, ByVal shift As Long, ByVal x As Long, ByVal y As Long)
Dim pMxDoc As IMxDocument
Set pMxDoc = ThisDocument
Dim SearchTol As Double
Dim pPoint As IPoint
  Set pPoint = pMxDoc.ActiveView.ScreenDisplay.DisplayTransformation.ToMapPoint(x, y)
  'Pass the point to the FindBoundary function along with the Map and search tolerance
  SearchTol = pMxDoc.SearchTolerance
  FindBoundary SearchTol, pPoint, pMxDoc.FocusMap
  'Message box the feature ID and feature class alias name
  'MsgBox pFeature.OID & " " & pFeature.Class.AliasName
pMxDoc.ActiveView.Refresh
End Sub
Private Function FindBoundary(SearchTol As Double, pPoint As IPoint, pMap As IMap)
'** This function is called by the subroutine SelectBoundary_MouseDown
'** this selects the boundary based on the click event of the user
    Dim pFeatSel As IFeatureSelection
  Dim pEnvelope As IEnvelope
  Dim pSpatialFilter As ISpatialFilter
  Dim pEnumLayer As IEnumLayer
  Dim pFeatureLayer As IFeatureLayer
  Dim pFeatureClass As IFeatureClass
  Dim pUID As New uid
  Dim pFeatureCursor As IFeatureCursor
  Dim pFeature As IFeature
  Dim pSelection As IFeatureSelection
  If pMap.LayerCount = 0 Then Exit Function
  'Clear any already selected Features
  pUID = "{40A9E885-5533-11D0-98BE-00805F7CED21}" 'IFeatureLayer
  Set pEnumLayer = pMap.Layers(pUID, False)
  pEnumLayer.Reset
  Set pFeatureLayer = pEnumLayer.Next
  Set pFeatureClass = pFeatureLayer.FeatureClass
  'Expand the points envelope to give better search results
  Set pEnvelope = pPoint.Envelope
  pEnvelope.Expand SearchTol, SearchTol, False
  ShapeFieldName = pFeatureLayer.FeatureClass.ShapeFieldName
  'Search each selectable feature layer for a feature
  'Return the first feature found
  Set pSpatialFilter = New SpatialFilter
  Set pSpatialFilter.Geometry = pEnvelope
  Set pSpatialFilter.OutputSpatialReference(ShapeFieldName) = pMap.SpatialReference
  pSpatialFilter.GeometryField = pFeatureLayer.FeatureClass.ShapeFieldName
  pSpatialFilter.SpatialRel = esriSpatialRelIntersects
  If pFeatureLayer.Selectable Then
    Set pSelection = pFeatureLayer
    pSelection.SelectFeatures pSpatialFilter, esriSelectionResultAdd, False
   Set pFeatSel = pSelection
   MsgBox (pFeatSel.SelectionSet.Count & " Features Selected from " & pFeatureLayer.FeatureClass.AliasName)
  End If
  End Function
bobbycorpuz
New Contributor II
CAN ANYBODY KNOWS HOW TO DO IT? TNX IN ADVANCE...
RebeccaStrauch__GISP
Hi Bobby,
Have you thought about trying the coding using ArcPy and Python?  I know it's sometimes easier to stick to a language that you know (and I'm not saying you have to switch, but recommended since VBA is being phased out with ArcMap), but Python actually is fairly easy to learn and the language of choice now, and you may get more responses if you want help with Python.  One other suggestion (so your question will get looks at by a larger group of developers) is to edit your original question and move it to the Developers​ group.
If you need some suggestions for how to get started in Python, check out this group
Python
and Python for ArcGIS | ArcGIS for Desktop
Sorry I can't be of more help, but I'm very rusty on VBA....although in a few months I'll dig into it again as I try to update some of my older apps.
These are just suggestions to get your question looked at by a larger, more developer oriented audience.
bobbycorpuz
New Contributor II
Thank you for your comment and recommendation Madam Rebecca Strauch​​​, I just need to finish the project that i am working on. Maybe i'll try working on arcPy and Python sooner. As for now, I will just stick to this rusty vba until this project is done. GODSPEED!
