I have published my map but it still will not load in Collector. Any advice?
Hi Matthew,
Just to add onto Michael's post, here's a link to the help documentation:
Create and share a map for data collection—Collector for ArcGIS | ArcGIS
Hope this helps,
Collector will only open web maps that have data from a feature service, i.e. editable.
Hi Matthew,
Hope this helps,
Hi Matthew,
I'm not clear on your issue. Collector for ArcGIS is available on Windows Phone.
EDIT: Collector for ArcGIS is available for Windows 10 tablets and PCs. You can get it here,
Collector for ArcGIS - Microsoft Store
Hope this helps,
Hello again Derek,
According to the Collector for ArcGIS - Microsoft Store link, the following is what shows on my phone:
I can't find any link for the Windows Phone.
To be more precise, I have a Microsoft Lumina 735 Windows Phone 8.1 Update 2.
Hi Matthew,
Apologies for the late reply, I was on business travel last week.
I'm also sorry, but I made a mistake in my previous post. As you pointed out, Collector for ArcGIS is NOT available on Windows Phone at this time, it's only available on Windows 10 tablets and PCs. I am sorry for my mistake.
FYI, this blog post was also just published:
ArcGIS Apps for the Field on the Windows Platform | ArcGIS Blog
Regarding your original question,
> Is there a work-around for the Collector for ArcGIS app on a Windows phone without using Survey123 or GeoForm?
I'm not exactly sure what you want to do, but have you tried to use Web AppBuilder for ArcGIS to create a web app for your web map data, then open it in a web browser on your Windows Phone? It supports editing workflows, but does not support being disconnected.
Hope this helps,
