Ports and Maritime Blog
Other Boards in This Place
Latest Activity
(7 Posts)
ShareUser
Esri Community Manager
Intended for database administrators as recommendations for establishing the product workspaces in an Enterprise Geodatabase (Oracle®, SQL Server®, PostgreSQL®).
Read more...
more
0 0 121
ShareUser
Mapping & Charting Solutions (MCS) Enterprise Databases Best Practices
Read more...
more
0 0 90
Kyle-Crawford
Earlier this year Esri released a data model for maritime ports. For this blog series, I want to highlight how we can leverage the information in the data model to start creating tailored applications that meet the specific needs of your organization.
In this third blog, I want to focus on how ArcGIS can be deployed to meet the safety and security needs of a maritime port. We are going to walk through how we can provide situational awareness and daily planning, and track incidents that may impact the port both locally and globally. To see this content in action please check this past webinar we conducted on security and safety operations.
Read more...
more
3 0 598
Kyle-Crawford
In this second blog, I want to focus on how easy it is to deploy your GIS out into the field.  We're going to walk through how we can streamline data collection, review processes, and share data both within and outside the organization to tackle inspections out on the terminal.
Getting Started
In the previous blog where I discussed lease management, I mentioned that successfully managing information starts with the data. Another key aspect of implementing a successful GIS is developing efficient workflows that involve connecting your data with your people to meet the desired mission objectives. One strategy for this requires examining how your organization handles the transmission of data about locations, assets, and personnel out in the field and back to the office.
What we've seen is that organizations are hungry for this information and trying to understand what is happening around their terminals and how they are maintaining their physical assets. Providing a solution that allows you to take what might be a paper-based workflow, and instead take a geographic approach first, is a way that can really drive success within your organization.
The Esri Ports data model is equipped with many layer options to store your data, represented by layers within feature datasets. Out of the box, the data model is designed to support many data scenarios that enhance your ability to fully support your port. For instance, you will notice the Terminal Inspections layer within the Property feature dataset. We have made it easy to manage key information related to conducting these inspections such as location, operator, and issue type through the included fields.
Throughout the data model, we have also included many preconfigured attribute domains. These provide a method for enforcing data integrity by limiting what can be placed in a field to a valid list or range of choices. As an example, for inspections we have defined a range of choices for the type of asset or location where an issue was discovered:
A key point to mention is that the data model was designed to provide a base for users to get started on their journey of creating and managing spatial data. We urge you to add fields and attribute domains where you deem necessary. These additions could be considered in future releases. We encourage you to keep us informed so the evolution of the ports data model stays in sync with the industry. The data model is flexible to meet the needs of your organization, and like the rest of the line of ArcGIS products, it is highly configurable.
After reviewing and making any necessary additions to the Terminal Inspection layer you are now ready to append any existing data you may have or start to create new data. The management and configuration of your data can all be done within ArcGIS Pro.
Once we have the necessary data populated into our Terminal Inspections layer, we are now ready to publish it to your portal whether that be ArcGIS Online or ArcGIS Enterprise. Once we have this data on the web, we can start to create configurable applications for members of our organization or even our terminal operators!
Enabling Attachments
Since this workflow includes the process of collecting data through inspections there is most likely a need to include or attach other forms of media to assets or locations. Now your current way of collecting data out in the field might include jotting notes on a piece of paper, capturing photos, and then going back to the office. The path of the information may stop there or a manual process of entering the data and renaming photos with asset identifiers would need to happen. Luckily, with the use of ArcGIS, we can leverage the data and enable attachments to ensure all the data captured in the field is now digitally stored and linked together.
You might notice within the ports data model there are no related tables that are used to store attachments. This was done to preserve a solid foundation for users to implement the model as they see fit. Luckily, enabling attachments is very simple and can be done before you share your data to either ArcGIS Online or ArcGIS Enterprise or after. To learn how to enable attachments to your feature class I suggest viewing this video. This video shows how to use the Enable Attachments geoprocessing tool in ArcGIS Pro to add documents and photos to your features. If you have already shared the layer with ArcGIS Online you can enable attachments through these simple steps.
KyleCrawford_4-1701448493625.pngOn the left is how attachments can be enabled within ArcGIS Pro. On the right is how attachments can be enabled in ArcGIS Online.
 Configuring Workflows
Now that we have transformed how this data is stored, we can continue the digital transformation by leveraging mobile and web applications! Before we dive into configuring these applications, this is a good time to evaluate the rest of the process. Who are the stakeholders that are going to be involved? How will this information flow between these roles? What technology needs to be included to make this successful?
Here is a great example of the process that I work through when designing workflows to meet the needs of our users. I believe in making a diagram like this as simple as possible to help explain the intended workflow to the stakeholders involved. This diagram showcases the intended roles, the configurable apps used to support the workflow, and how this data will be stored and made accessible to others.
In this example we have our inspectors tasked with reporting any issues that they come across while in the field. Now depending on your intended workflow, you have the option to leverage one of the many ArcGIS mobile applications. If you're not familiar with these very powerful applications, I recommend you check out a great course we offer, Field Data Collection and Management Using ArcGIS. In this course, you will get hands-on experience with Field Maps, QuickCapture, and Survey123! After this course, you will be able to configure mobile apps, quickly capture real-time field observations, and monitor fieldwork progress using a dashboard.
Now that inspectors have captured any issues; we can leverage that data stored in ArcGIS to continue the workflow. Since major issues could be discovered we may want someone from engineering or operations to review these findings. Instead of reviewing this information in a tabular format, we can configure a dashboard that provides spatial and quantitative insight into all the issues captured by the terminal inspectors. Within this dashboard, we can embed a Survey123 form which can be leveraged by the reviewer to provide comments and feedback for individual issues. Through the review, they may also find the need to increase the issue rating or possibly provide an estimated cost of repair. The great thing about this part of the workflow is that we can just edit the existing data from the initial inspection record collected in the field by embedding a survey form into the dashboard
While all of this work is happening, staff that might hold a terminal management or executive role within the organization can track the progress in their own tailored dashboard. Those in that role have different needs and requirements that need to be met. For instance, being able to see the number of issues per terminal or the average cost of repairs might be a high priority. Again, everything we have seen so far is supported by that one Terminal Inspections layer coming from the data model. All you need to do is define the workflow, and the roles involved, and then configure applications to meet the overall business goal.
We have also heard the need for ports to share information regarding issues found with terminal operators. Depending on the agreement between the two parties the operator could be reliable for the maintenance of specific assets that they utilize. This transfer of information could be done through various traditional ways whether that be PDFs, emails, or phone calls. However, now that we have this data in a web layer, we can use the flexibility of ArcGIS to share this information and provide a spatial context.
To safely share this data, we may want to create a layer view that provides stakeholders with alternative visual and tabular representations of a dataset that includes only relevant information to their operations. For example, you can filter out data that relates to individual terminal operators and only return issues relating to the area of their operations.  We can then leverage this new way of sharing information to configure other dashboards that serve individual operators!
Conclusion
Getting started with the Maritime Ports data model has never been easier! Coupled with the ArcGIS system, the ports data model is easy to deploy and more cost-effective for organizations that manage maritime port assets.
Today, we focused on just one layer within the data model, which provided insight for internal and external stakeholders. Using one source of the truth, we were able to configure the entire workflow to support terminal inspections. To view the applications, we just discussed in action check out this video from a previous webinar.
When it comes to implementing field mobility workflows there is inherently a personnel aspect that can involve discussion around tech adoption and digital transformation. And trust me I get that this can be hard, but I recently read a great article by Esri Canada’s Matthew Lewin where he outlines “Seven Practical Tips for Driving Tech Adoption—Starting Today”. So, whether you’re still learning how to spell GIS or have been in the field for 20 years I highly recommend giving it a read.
We look forward to sharing more ways to leverage the data model in our upcoming blogs. Stay tuned!
more
2 0 497
Kyle-Crawford
Earlier this year we released a data model for maritime ports and so for the next couple of blogs, I want to highlight how we can leverage the information in the data model to start creating these tailored applications to meet the specific needs of your organization.
In this first blog, I want to focus on how you can leverage your lease management information with ArcGIS. We're going to walk through how we can streamline the lease planning process, facilitate financial insight, and amplify your lease marketing.
Read more...
more
6 0 586
NadineHernandez
This webinar is designed to help port professionals begin their journey with GIS by focusing on simple applications that can be quickly implemented and deliver significant returns on investment.
Read more...
more
0 0 658
Kyle-Crawford
Earlier today Esri posted the first-ever industry data model for managing Maritime Port (MP) assets. This data model continues Esri’s efforts in providing industry-specific template data models. The MP 2023 data model provides Maritime Port organizations with an implementation-ready configuration for ArcGIS. This data model template is provided as a free download for all to use.
Why Create This Data Model
The goal of the MP 2023 data model is to make it easier, quicker, and more cost-effective for organizations responsible for the management of Maritime Port assets to implement the ArcGIS system. The MP 2023 data model accomplishes this by freely providing a data model template that demonstrates a best practice configuration of the Esri geodatabase to address the system of record needs of MP organizations.
How was this Data Model Created
Creating a new industry data model requires an immense amount of information.  More information than any one person or organization contains. Fortunately, many persons from around the world were willing to share their knowledge and time to help bring this data model to life. This group effort from organizations big and small, public and private, incorporates years of industry knowledge into this data model.
Best Practice Application of ArcGIS Technology
MP 2023 was configured to take advantage of the latest capabilities provided by ArcGIS technology. This includes recent enhancements such as attribute rules as well as many preconfigured attribute domains. Included in MP 2023 are attribute rules to automate attribute population such as unique address identifiers and full address names. These serve as examples that could be expanded upon as you go through your implementation of the data model!
Sample Data
Included in the download file stored on the Maritime Ports industry page of the Esri Community is an ArcGIS Pro Project which includes a sample dataset. This dataset provides great examples of the many facilities that play a part in the daily operation of a Maritime Port.
Data Dictionary
As we all know, writing a data dictionary is not fun, but it is very important for explaining the what, the how, and the why of the data model. The data dictionary is included in the download file as a PDF document.
This data dictionary includes descriptions of each feature dataset and the corresponding feature classes. For each feature class, a full description of each attribute that is appropriate is provided. Each user of the data model is encouraged to review this document before getting started. As well as include any amendments deemed necessary.
How to Download
The data model, sample data, ArcGIS Pro project, and data dictionary are available as a single download from the Ports and Maritime industry page on the Esri Community site. You can download it directly with this link.
Getting Started
Included in the project are the following Maps: Editor and Web Map. These maps include the same layer properties, however in order to share to the web, layer symbology has been modified in the Web Map.
As a default, these maps reference the sample data geodatabase which utilizes a spatial reference system different than your own. To get started with your implementation use the included Change GDB Spatial Reference tool found in the Change Spatial Reference toolbox. **This tool does require at the minimum an ArcGIS Pro Standard license. The input of this tool will be the included Maritime Ports geodatabase which provides only the data model schema. Select the appropriate output spatial reference, folder location, and name of the output geodatabase. Finally, use this method to update the data sources of all the layers.
As noted previously, this data model is the cumulation of the input of many persons. This data model can only evolve with your feedback. If you have suggestions for improving this data model or see something that requires correction to help the next person, please reply to this blog and post your feedback, or you can email me directly at: kcrawford@esri.com
more
5 2 3,563
64 Subscribers
