crime analysis toolbox
1902
7
03-31-2018 04:36 AM
Shoaibkhalid
Hi. I need a little help in running the Predictive analysis in Repeat and near repeat exercise. In crime analysis toolbox, the "Calculate Prediction Zone" tool doesn't work.
DanPatterson_Retired
put everything in a folder without spaces in it and run from there
XanderBakker
Esri Esteemed Contributor
Are you sure you have arcrest installed. The error message is stating "No module named arcrest.security". ArcREST/security.py at master · Esri/ArcREST · GitHub
BenjaminMittler
Occasional Contributor III
Sorry to piggyback on this topic. Is there a link to where I can access the Crime Analysis Toolbox? I did some googling and only saw the the toolbox on the esriUK page and the github site. I thought I remembered seeing the toolbox somewhere on the official esri US page at one point.
Thanks
JoeBorgione
A google search on arcgis Crime Analysis Toolbox reveals :  GitHub - Esri/crime-analysis-toolbox: The Crime Analysis Toolbox contains a series of ArcGIS geoproc...
That should just about do it....
BenjaminMittler
Thanks, yes, I saw this. I didn't want to naigate to GitHub because I figured I would end up with an email from IT shortly after..
AllisonMuise1
The Crime Analysis toolbox is shipped as part of this solution:
Repeat and Near Repeat Analysis | ArcGIS for Local Government
AllisonMuise1
Shoaib khalid‌ It looks to me like the Crime Analysis toolbox has been moved out to a different directory than the rest of the solution files.
If it is, could you post a screenshot of the directory containing the toolbox?
Did you download this from the Solutions site, or directly from GitHub?
