Faild to connect to databese - ArcCatalog
3233
10-29-2012 08:07 AM
MariamAl_Shamisi
Hi
I am facing problem while trying to export data from arcmap, it gives me this masseage
[ATTACH=CONFIG]18805[/ATTACH]
I tried to change the path and it gives me the same massage, I want to export the data to " File and Personal Geodatabase Feature Class " but when I export it to a shapefile it works !!
when I open the arcCatalog to view the file it gives me this masseage
[ATTACH=CONFIG]18806[/ATTACH]
I am running ArcGIS 10 and I am using windows 7
Thankx
RobertPincus
I do not think you are actually connected to a database. You need to double click either Springfield_results.gdb or Springfield_results1.gdb. It appears that ArcMap is trying to save to Home-Project1_Spingfield... and not a database.
The second problem might be resolved after fixing this one.
Robert.
by Anonymous User
Not applicable
Original User: Mariam56
Thank you for your replaying
I double click Springfield_results.gdb and it give me the same error !! and when I tried to open the description view in Arc Catalog it gives me this massege
[ATTACH=CONFIG]18812[/ATTACH]
I download this data from " Making Spatial Decisions Using GIS Workbook " CD
RobertPincus
Check the permissions and make sure they are not set to read only.
