Is there a new tool in Pro that will offset routes that overlap each other? I would prefer to symbolically display the offset but if that does not exist than physically moving the lines would do as well. I don't need to keep it as part of a network, it is just for display. I have seen many posts on this issues from the past decade, but I still have not found a simple and appropriate (no special licensing required) solution. Seems like such a standard thing to be able to map overlapping bus routes clearly, especially when so much transit GTFS data is now available for free.
