Hi ,
I have published Vector tiles map using ArcGIS Pro. The vector tile services has been found under hosted tab in ArcGIS Server rest url. But when I compare the vector tile with the basemap service of ArcGIS, the content is entirely different. For https://basemaps.arcgis.com/arcgis/rest/services/World_Basemap_v2/VectorTileServer I get the json details
But in my local enterprise I get a different result.
Thanks
Aditya
Solved! Go to Solution.
Hi @ADITYAKUMAR1,
You can add ?f=json into the URL to get the same output or click the JSON button which is just under "Home" in your second screenshot.
A
Hi @ADITYAKUMAR1,
A
@A_Wyn_Jones Thanks for the response.
As suggested I have added it and its showing the result. But I am confused why the URL from ESRI is showing the same without putting ?JSON while I explicitly need to add JSON parameter?
Thanks
Aditya Kumar
@ADITYAKUMAR1 No problem.
I believe Esri has customised their endpoints to prevent casual browsing of their services.
Another example is that the services rest endpoint is restricted here: https://basemaps.arcgis.com/arcgis/rest/services
For further context, this aligns with best practice for ArcGIS Server. Please look at SS07 here:
