I have this code, same code I posted yesterday but different piece. In 10.2.2 I am trying to get the script to write all print outputs to a text file. Code block in question starts at line 18.
import arcpy, os, sys arcpy.env.workspace = arcpy.GetParameterAsText(0) def get_size(start_path = arcpy.env.workspace): total_size = 0 for dirpath, dirnames, filenames in os.walk(start_path): for f in filenames: fp = os.path.join(dirpath, f) total_size += os.path.getsize(fp) return round((total_size / float(1048576)), 2) print "Total Size before Compact " + str(get_size()) + "mb" results = open("R:\\results.txt","w") results.write("Total Size before Compact " + str(get_size()) + "mb" + '\n') feature_classes = [] for dirpath, dirnames, filenames in arcpy.da.Walk(arcpy.env.workspace, datatype="Container"): for dirname in dirnames: if ".gdb" in dirname: arcpy.Compact_management(os.path.join(dirpath, dirname)) print "Successfully compacted " + dirname results.write("Successfully compacted " + dirname + '\n') results.close()
There are hundreds of GDBs in this workspace. In the ArcMap console, it returns each GDB it finds and prints "Successfully compacted this.gdb". However, when I try to write the print to a file it only writes the last GDB in the list. How do I get it to list every GDB it successfully compacts in the text file? Thanks!
