When I try to install the toolbar with the Combo box, I have this error :
File "<string>", line 1
SyntaxError: can't assign to operator
Usually i'm able to resolve the syntax error but I have no clue for this one.
Here my code :
import arcpy
import pythonaddins
class LayersComboBoxClass(object):
"""Implementation for Python_Add-In_addin.combo_box (ComboBox)"""
def __init__(self):
self.items = []
self.editable = False
self.enabled = True
self.dropdownWidth = 'WWWWWW'
self.width = 'WWWWWWWWWWWWWWWWWWWW'
def onSelChange(self, selection):
layer = r"S:\Geomatique\Pierre-Luc\SPVM\Corridors_Scolaire\Carto.gdb\Ecoles"
arcpy.SelectLayerByAttribute_management(layer, "NEW_SELECTION", "DESC_LIEU = '" + selection + "'")
arcpy.RefreshActiveView()
def onEditChange(self, text):
pass
def onFocus(self, focused):
self.mxd = arcpy.mapping.MapDocument('current')
layer = arcpy.mapping.ListLayers(self.mxd, "Ecoles")[0]
#self.items = []
values = [row[0] for row in arcpy.da.SearchCursor(layer, ["DESC_LIEU"])]
for uniqueVal in sorted(set(values)):
self.items.append(uniqueVal)
def onEnter(self):
pass
def refresh(self):
pass
Thanks for your help
