Addin Objects in Python Interpreter Window
3625
03-31-2014 11:28 AM
JodyMacEachern1
Hi:
I created an add in that found the unique values in a field and listed the output to the python window. At 10.0 I could access the objects from the addin in the Python window; at 10.2.1 this is no longer the case.
For example, the addin was called listunique, and the unique values were stored in a Python list called unique. After running the addin I could use access that list in the Python window as
listunique.unique
Is there any way to make the objects from an addin accessible in the Python window?
Jody
ChadChurchill
I encountered this same scenario today when I switched from 10.1 to 10.3. Did you ever find a solution to this?
Chad
