Hello, Thanks for the immediate response.However, all ID_* fields remained after I ran the code. (no error message)We need more try to figure out how to make the "delete multiple fields" work.:)ElaineThe whole code is
##AddJoin feature layers to a feature layer
##Elaine Kuo
##01 July 2013
#Import standard library modules
import arcgisscripting
import os
#Create the Geoprocessor object
gp = arcgisscripting.create(9.3)
gp.QualifiedFieldNames = "UNQUALIFIED"
#Set the input workspace
workingfolder= "H:/temp_D/test"
gp.Workspace = workingfolder
#Set the output workspace
outputfolder= "H:/temp_D"
outWorkspace= outputfolder
source_fc = "H:/temp_D/testt/A_grid.shp"
#Get a list of the featureclasses in the input folder
fcs = gp.ListFeatureClasses()
gp.Toolbox = "Data Management"
# Make a FeatureClass layer
gp.MakeFeatureLayer_management (source_fc, "source_lyr")
# A counter to separate the first time through the loop from all other times
counter = 0
# Loop through every item in the list that was just generated
for fc in fcs:
if counter == 0:
# set up first Layer for AddJoin
gp.AddJoin_management("source_lyr", "GID", fc, "GID", "KEEP_ALL")
else:
# set up second and following Layers for AddJoin
gp.AddJoin_management("source_lyr", "A_grid.GID", fc, "GID", "KEEP_ALL")
counter += 1
# convert a layer to a featureclass
out_name = gp.Describe("source_lyr").name
out_name = gp.ValidateTableName(out_name, outputfolder)
out_shape = outputfolder + "/" + out_name + ".shp"
gp.CopyFeatures_management ("source_lyr", out_shape)
# delete Field (need to clean up with a lot more ID fields that the code you have below since now there are 50 GID values.)
fieldList = gp.ListFields(out_shape)
for field in fieldList:
if field.name[1:3] == "ID_":
gp.deletefield (out_shape, field.name)
# Don't bother removing 50 joins, just kill the layer
# clear memory of layers
gp.Delete("source_lyr")
gp.AddMessage(gp.GetMessages())
print gp.GetMessages()
