Thanks Dan for the quick reply. The issue only occurs when the script tool is being run inside ArcMap and I select a raster layer as the input. Here is the code:
# Import arcpy module
import arcpy
# Script arguments
Forest_tif = arcpy.GetParameterAsText(0)
# required arg - comment following in production
if Forest_tif == '#' or not Forest_tif:
Forest_tif = "C:\\GIS\\KML\\publish\\oberniki\\Forest.tif" # provide a default value if unspecified
Forest_colour_tif = arcpy.GetParameterAsText(1)
if Forest_colour_tif == '#' or not Forest_colour_tif:
Forest_colour_tif = "C:\\GIS\\KML\\publish\\oberniki\\Forest_colour.tif" # provide a default value if unspecified
# Local variables (files in same path as toolbox/script)
Forest_tif_lyr = "Forest.tif.lyr"
Forest_tif_clr = "Forest.tif.clr"
# Set Geoprocessing environments
arcpy.env.outputCoordinateSystem = "GEOGCS['GCS_WGS_1984',DATUM['D_WGS_1984',SPHEROID['WGS_1984',6378137.0,298.257223563]],PRIMEM['Greenwich',0.0],UNIT['Degree',0.0174532925199433]]"
# Make Raster Layer
arcpy.MakeRasterLayer_management(Forest_tif, "temp_layer", "", "", "")
# Apply Symbology From Layer
arcpy.ApplySymbologyFromLayer_management("temp_layer", Forest_tif_lyr)
# Add Colormap
arcpy.AddColormap_management("temp_layer", "#", Forest_tif_clr)
# Copy Raster to generate RGB
arcpy.CopyRaster_management("temp_layer", Forest_colour_tif, "", "", "255", "NONE", "ColormapToRGB", "8_BIT_UNSIGNED", "NONE", "NONE")
