Hello,
I'm not sure if this is the right place to send this so please correct me if I am wrong.
I had a script that converted data from a clients site to a usable GIS format until they changed the output. I've tried two different directions with no luck. Due to how an earlier part of the script works, CSV to Table, and the nature of the data being converted; the 'total_length' field that's imported might end up being a string or an integer (TableToTable conversion will not work). I need it to look at the field type and if it's already an integer then populate the 'length_val' field with the number. If it's a string then strip it down to the number (typically the greater than, less than or tilde off the front) and populate the 'length_val' field.
In other words:
If 'total_length' = STRING, then send only the number to 'length_val'
Otherwise, if 'total_length' = INTEGER, then calculate the field.
I've been using update cursors to do a lot of the rest of the work, but that doesn't have to be the case. Any assistance would be great.
John
Row[3] = 'total_length'
Row[17] = 'length_val'
---First Attempt---
with arcpy.da.UpdateCursor(aoi_table_gdb,aoi_fields) as cursor:
totlen = "total_length" #<--- This was just an idea
fields = arcpy.ListFields(aoi_table_gdb)
for field in fields:
if field.name = '"'+ totlen +'"' and field.type = String:
for row in cursor:
if row[3] == None:
row[17] = None
elif row[3].find(str('~ ')) > -1:
row[17] = row[3].lstrip(str('~ '))
elif row[3].find(str('> ')) > -1:
row[17] = row[3].lstrip(str('> '))
elif row[3].find(str('< ')) > -1:
row[17] = row[3].lstrip(str('< '))
else:
row[17] = row[3]
else:
for row in cursor:
row[17] = row[3]
cursor.updateRow(row)
---Second Attempt---
for row in cursor:
#Length Value
if row[3] == None:
row[17] = None
arcpy.AddWarning("A. Row: " + str(row[1]) + " - " + str(row[3]))
elif row[3].isdigit():
row[17] = row[3]
arcpy.AddWarning("B. Row: " + str(row[1]) + " - " + str(row[3]))
else:
length = filter(unicode.isdigit, row[3])
row[17] = length
arcpy.AddWarning("C. Row: " + str(row[1]) + " - " + str(row[3]))
