arcpy.sa.TopoToRaster Visual Fortran error
5129
15
04-05-2016 10:09 AM
RodrigoRocha
Hello everybody , I'm trying to run Topo to Raster by Arcpy, in a ArcGIS Desktop 10.2 , however, every time appears the following warning and ArcGis closes. I did an experiment by turning the Topo to Raster directly from ArcToolbox and worked perfectly. I also tried to run the tool in ModelBuilder , successfully. The error message are attached.
RodrigoRocha
Hi Peter,
After 2 years without accessing this forum, due to personal problems, the files I used in a new attempt is attached, but i'm still frustrated.
Thank you very much in advance
PeterWilson
Hi Rodrigo Rocha
I'll have a look at the following and get back to you shortly. Sorry I've not been on the forums either for a while. I've changed my career direction from geospatial to data science.
Regards Peter
RodrigoRocha
Steve, what intrigues me is the fact to error only when running in arcpy. If I use the same inputs and cellsize in TopoToRaster directly from ArcToolbox, can generate raster without any problem !!!
The solution presented by the link: https://geonet.esri.com/thread/102133#comment-468079 would not be the cause, for my Desktop is already with such a configuration ...
This problem is occurring in ArcGIS 10.2 ...
Any help is still welcome
Thanks for help and still available.
Rodrigo
SteveLynch
Rodrigo
What about trying it with fewer contour lines (i.e. select about 80%)?
What about in a standalone script?
How many columns and rows does the output raster have?
-Steve
RodrigoRocha
Hello Steve, how long did I remain without accessing this forum!
I followed your suggestion and used a region with fewer outline lines (very small).
I did not quite understand your other suggestion of using a stand-alone script.
The shapefiles I used, as well as the script are attached.
I tried to run it again in the Python terminal of Arcgis (10.2) again,
but the same error described at the beginning persists.
SteveLynch
Rodrigo
Please email me (slynch@esri.com) a zipped copy of the data and the parameters that you are using.
-Steve
