arcrest geometryfilter?
3696
05-30-2016 07:09 PM
RichardWebb2
New Contributor II
Is there a better way of getting that geometry into the second query? Not happy with line 28
from __future__ import print_function
from arcrest.ags import FeatureLayer
import arcpy
import json
if __name__ == "__main__":
    arcpy.env.overwriteOutput = True
    lgaUrl = "http://services.thelist.tas.gov.au/arcgis/rest/services/Public/CadastreAndAdministrative/MapServer/4"
    flLGA = FeatureLayer(
        url=lgaUrl)
    lgaWhereClause = "NAME = 'Launceston'"
    outSR = '28355'
##    outFC="C:\Scripts\data.gdb\LGA"
##    # get lga geometry
##    lgaGeom = flLGA.query(where=lgaWhereClause,out_fields='shape',returnGeometry=True,returnFeatureClass=True,out_fc=outFC,outSR=outSR)
    lgaGeom = flLGA.query(where=lgaWhereClause,out_fields='shape',returnGeometry=True,outSR=outSR)
    geomText = lgaGeom.toJSON
    geomRings = json.loads(geomText)
    for key, value in geomRings.iteritems():
        if key == 'features':
            features = str(value)
    features = features.replace("[{u'geometry': ","").replace(", u'attributes': {}}]","").replace("{u'rings':","{'rings':")
    # change to Crown Licenses
    crownUrl = "http://services.thelist.tas.gov.au/arcgis/rest/services/Public/CadastreAndAdministrative/MapServer/3"
    flCrown = FeatureLayer(
    url=crownUrl)
    crownWhereClause = "1=1"
    outFC="C:\Scripts\data.gdb\CrownLicenses"
    geometryType = "esriGeometryPolygon"
    # get crownLicenses
    crownLicenses =
38.
flCrown.query(where=crownWhereClause,geometry=features,out_fields='objectid,pid,shape',returnGeometry=Tr
e,returnFeatureClass=True,out_fc=outFC,geometryType=geometryType,inSR=outSR,outSR=outSR)
AndrewChapkowski
Try this:
import arcrest
  fl_url = "https://site.com/arcgis/rest/services/reference/adminboundaries/FeatureServer/0"
  token_url = "https://site.com/arcgis/admin/generateToken"
  org_url="https://site.com/arcgis"
  username = "admin"
  pw = "some password"
  where = "ISO_CC = 'US'"
  sh = arcrest.AGSTokenSecurityHandler(username=username,
  password=pw,
  org_url=org_url,
  token_url=token_url)
  fl = arcrest.ags.FeatureLayer(url=fl_url,securityHandler=sh)
  fs = fl.query(where=where)
  print ("Found %s features with the where clause: %s" % (len(fs), where) )
  if len(fs.features) > 0:
     feature = fs.features[0]
     geom = feature.geometry
     geomFilter = arcrest.filters.GeometryFilter(geomObject=geom)
     result = fl.query(where=where, geomtryFilter=geomFilter, as_json=True) # set as_json=False for the featureset object
     print ("Found %s features with the where clause: %s and geometry filter" % (len(result['features']), where) )
JoshuaBixby
MVP Esteemed Contributor
Have you inquired about this at the ArcREST GitHub site?  If so, what was the response?  If not, it might be worth asking there as well while you wait for feedback here.
AndrewChapkowski
Try this:
import arcrest
  username = "admin"
  password=pw,
  org_url=org_url,
