import arcpy from arcpy import env arcpy.env.overwriteOutput = True env.workspace = "C:\Temp\CCAP.gdb" CCAP = r'Database Servers\DSD15_SQLEXPRESS.gds\TonyTwoWay (VERSION:dbo.DEFAULT)\TonyTwoWay.DBO.CCAP' CCAP2 = "C:\Temp\CCAP.gdb" arcpy.FeatureClassToGeodatabase_conversion(CCAP, CCAP2)
import arcpy from arcpy import env import os arcpy.env.overwriteOutput = True env.workspace = "C:\Temp\CCAP.gdb" TonyTwoWay_DBO_CCAP = "C:\Temp\CCAP.gdb\TonyTwoWay.DBO.CCAP" if arcpy.Exists(TonyTwoWay_DBO_CCAP): arcpy.Delete_management("C:\Temp\CCAP.gdb\TonyTwoWay_DBO_CCAP") CCAP = r'Database Servers\DSD15_SQLEXPRESS.gds\TonyTwoWay (VERSION:dbo.DEFAULT)\TonyTwoWay.DBO.CCAP' CCAP2 = "C:\Temp\CCAP.gdb" arcpy.FeatureClassToGeodatabase_conversion(CCAP, CCAP2)
import arcpy, os arcpy.env.overwriteOutput = True arcpy.env.workspace = "C:\Temp\CCAP.gdb" TonyTwoWay_DBO_CCAP = "C:\Temp\CCAP.gdb\TonyTwoWay.DBO.CCAP" CCAP = r'Database Servers\DSD15_SQLEXPRESS.gds\TonyTwoWay (VERSION:dbo.DEFAULT)\TonyTwoWay.DBO.CCAP' CCAP2 = "C:\Temp\CCAP.gdb" if arcpy.Exists(CCAP2): arcpy.Delete_managementCCAP2) arcpy.FeatureClassToGeodatabase_conversion(CCAP, CCAP2)
import arcpy from arcpy import env import os from datetime import datetime as d startTime = d.now() arcpy.env.overwriteOutput = True arcpy.env.workspace = "C:\Temp\CCAP.gdb" TonyTwoWay_DBO_CCAP = "C:\Temp\CCAP.gdb\TonyTwoWay.DBO.CCAP" CCAP = r'Database Servers\DSD15_SQLEXPRESS.gds\TonyTwoWay (VERSION:dbo.DEFAULT)\TonyTwoWay.DBO.CCAP' CCAP2 = "C:\Temp\CCAP.gdb" if arcpy.Exists(CCAP2): arcpy.Delete_management(CCAP2) arcpy.CreateFileGDB_management("C:\Temp", "CCAP.gdb") arcpy.FeatureClassToGeodatabase_conversion(CCAP, CCAP2) try: print '(Elapsed time: ' + str(d.now() - startTime)[:-3] + ')' except Exception, e: # If an error occurred, print line number and error message import traceback, sys tb = sys.exc_info()[2] print "Line %i" % tb.tb_lineno print e.message
import arcpy from arcpy import env import os from datetime import datetime as d startTime = d.now() arcpy.env.overwriteOutput = True arcpy.env.workspace = "C:\Temp\CCAP.gdb" TonyTwoWay_DBO_CCAP = "C:\Temp\CCAP.gdb\TonyTwoWay.DBO.CCAP" CCAP = r'Database Servers\DSD15_SQLEXPRESS.gds\TonyTwoWay (VERSION:dbo.DEFAULT)\TonyTwoWay.DBO.CCAP' CCAP2 = "C:\Temp\CCAP.gdb" CCAP3 = "C:\Temp\CCAP.gdb\TonyTwoWay_DBO_CCAP" if arcpy.Exists(CCAP3): arcpy.Delete_management(CCAP3) arcpy.FeatureClassToGeodatabase_conversion(CCAP, CCAP2) try: print '(Elapsed time: ' + str(d.now() - startTime)[:-3] + ')' except Exception, e: # If an error occurred, print line number and error message import traceback, sys tb = sys.exc_info()[2] print "Line %i" % tb.tb_lineno print e.message
