Hi margarita stevia ,
Could you validate if this works for you? I will create the additional p-value raster and a mask raster containing the pixels with value 1 where the condition (p-value <= 0.05 and positive correlation) is met. The calculation of the p-value is based on the code provided by Dan Patterson
It seems that the resulting areas (blue pixels) are near the rivers . Does that make sense?
See code below:
def main():
print "load modules..."
import arcpy
arcpy.env.overwriteOutput = True
import numpy as np
template1 = r'C:\GeoNet\Pvalue\Send\NDVI\r{0}_WUE.TIF'
template2 = r'C:\GeoNet\Pvalue\Send\temp\r{0}_TEM.TIF'
nodata = -3.4028235e+38
out_ras_corr = r'C:\GeoNet\Pvalue\Send\Results\correlation_v01.TIF'
out_ras_pear = r'C:\GeoNet\Pvalue\Send\Results\pearson_v01.TIF'
out_ras_pval = r'C:\GeoNet\Pvalue\Send\Results\pvalue_v01.TIF'
out_ras_mask = r'C:\GeoNet\Pvalue\Send\Results\mask_v01.TIF'
max_pval = 0.05
min_corr = 0
mask_val = 1
no_mask_val = 0
print "create nested numpy array list..."
lst_np_ras = []
for i in range(1, 5):
ras_path1 = template1.format("%03d" % (i,))
print " - ", ras_path1
ras_np1 = arcpy.RasterToNumPyArray(ras_path1)
ras_path2 = template2.format("%03d" % (i,))
print " - ", ras_path2
ras_np2 = arcpy.RasterToNumPyArray(ras_path2)
lst_np_ras.append([ras_np1, ras_np2])
print "read props numpy raster..."
ras_np = lst_np_ras[0][0]
rows = ras_np.shape[0]
cols = ras_np.shape[1]
print " - rows:", rows
print " - cols:", cols
print "create output numpy array..."
ras_path = template1.format("%03d" % (1,))
raster = arcpy.Raster(ras_path)
ras_np_res_corr = np.ndarray((rows, cols))
ras_np_res_pear = np.ndarray((rows, cols))
ras_np_res_pval = np.ndarray((rows, cols))
ras_np_res_mask = np.ndarray((rows, cols))
print " - out rows:", ras_np_res_corr.shape[0]
print " - out cols:", ras_np_res_corr.shape[1]
print "loop through pixels..."
pix_cnt = 0
for row in range(rows):
for col in range(cols):
pix_cnt += 1
if pix_cnt % 5000 == 0:
print " - row:", row, " col:", col, " pixel:", pix_cnt
lst_vals1 = []
lst_vals2 = []
try:
for lst_pars in lst_np_ras:
lst_vals1.append(lst_pars[0][row, col])
lst_vals2.append(lst_pars[1][row, col])
lst_vals1 = ReplaceNoData(lst_vals1, nodata)
lst_vals2 = ReplaceNoData(lst_vals2, nodata)
correlation = CalculateCorrelation(lst_vals1, lst_vals2, nodata)
ras_np_res_corr[row, col] = correlation
pearson = CalculatePearsons(lst_vals1, lst_vals2, nodata)
ras_np_res_pear[row, col] = pearson
pvalue = CalculatePvalue(lst_vals1, lst_vals2, nodata)
ras_np_res_pval[row, col] = pvalue
if pvalue == nodata:
mask = nodata
elif (correlation >= min_corr) and (pvalue <= max_pval):
mask = mask_val
else:
mask = no_mask_val
ras_np_res_mask[row, col] = mask
except Exception as e:
print "ERR:", e
print " - lst_vals1:", lst_vals1
print " - lst_vals2:", lst_vals2
pnt = arcpy.Point(raster.extent.XMin, raster.extent.YMin)
xcellsize = raster.meanCellWidth
ycellsize = raster.meanCellHeight
print "Write output rasters..."
print " - ", out_ras_corr
ras_res_corr = arcpy.NumPyArrayToRaster(ras_np_res_corr, lower_left_corner=pnt, x_cell_size=xcellsize,
y_cell_size=ycellsize, value_to_nodata=nodata)
arcpy.CopyRaster_management(ras_res_corr, out_ras_corr)
arcpy.DefineProjection_management(in_dataset=out_ras_corr, coor_system="GEOGCS['GCS_WGS_1984',DATUM['D_WGS_1984',SPHEROID['WGS_1984',6378137.0,298.257223563]],PRIMEM['Greenwich',0.0],UNIT['Degree',0.0174532925199433]]")
print " - ", out_ras_pear
ras_res_pear = arcpy.NumPyArrayToRaster(ras_np_res_pear, lower_left_corner=pnt, x_cell_size=xcellsize,
arcpy.CopyRaster_management(ras_res_pear, out_ras_pear)
arcpy.DefineProjection_management(in_dataset=out_ras_pear, coor_system="GEOGCS['GCS_WGS_1984',DATUM['D_WGS_1984',SPHEROID['WGS_1984',6378137.0,298.257223563]],PRIMEM['Greenwich',0.0],UNIT['Degree',0.0174532925199433]]")
print " - ", out_ras_pval
ras_res_pval = arcpy.NumPyArrayToRaster(ras_np_res_pval, lower_left_corner=pnt, x_cell_size=xcellsize,
arcpy.CopyRaster_management(ras_res_pval, out_ras_pval)
arcpy.DefineProjection_management(in_dataset=out_ras_pval, coor_system="GEOGCS['GCS_WGS_1984',DATUM['D_WGS_1984',SPHEROID['WGS_1984',6378137.0,298.257223563]],PRIMEM['Greenwich',0.0],UNIT['Degree',0.0174532925199433]]")
print " - ", out_ras_mask
ras_res_mask = arcpy.NumPyArrayToRaster(ras_np_res_mask, lower_left_corner=pnt, x_cell_size=xcellsize,
arcpy.CopyRaster_management(ras_res_mask, out_ras_mask)
arcpy.DefineProjection_management(in_dataset=out_ras_mask, coor_system="GEOGCS['GCS_WGS_1984',DATUM['D_WGS_1984',SPHEROID['WGS_1984',6378137.0,298.257223563]],PRIMEM['Greenwich',0.0],UNIT['Degree',0.0174532925199433]]")
def CalculateCorrelation(a, b, nodata):
import numpy
try:
coef = numpy.corrcoef(a,b)
return coef[0][1]
except:
return nodata
def ReplaceNoData(lst, nodata):
res = []
for a in lst:
if a < nodata / 2.0:
res.append(None)
else:
res.append(a)
return res
def CalculatePearsons(a, b, nodata):
import numpy as np
from scipy.stats import pearsonr
try:
x = np.array(a)
y = np.array(b)
r, p = pearsonr(a, y)
return p
except:
return nodata
def CalculatePvalue(a, b, nodata):
import numpy as np
from scipy.stats import stats
try:
x = np.array(a)
y = np.array(b)
r, p_val = stats.pearsonr(x, y)
return p_val
except:
return nodata
if __name__ == '__main__':
main()
