Calculate Correlation and P-value between rasters
2810
11
07-02-2019 10:15 PM
margaritastevia
New Contributor II
Hi Xander Bakker‌ I have used this script and got two rasters  "correlation" and "pearson". Which one is the P-value?
Branched from https://community.esri.com/thread/200534-re-correlation-between-two-different-rasters
XanderBakker
Esri Esteemed Contributor
Hi margarita stevia ,
Could you validate if this works for you? I will create the additional p-value raster and a mask raster containing the pixels with value 1 where the condition (p-value <= 0.05 and positive correlation) is met. The calculation of the p-value is based on the code provided by Dan Patterson
It seems that the resulting areas (blue pixels) are near the rivers . Does that make sense?
See code below:
def main():
    print "load modules..."
    import arcpy
    arcpy.env.overwriteOutput = True
    import numpy as np
    template1 = r'C:\GeoNet\Pvalue\Send\NDVI\r{0}_WUE.TIF'
    template2 = r'C:\GeoNet\Pvalue\Send\temp\r{0}_TEM.TIF'
    nodata = -3.4028235e+38
    out_ras_corr = r'C:\GeoNet\Pvalue\Send\Results\correlation_v01.TIF'
    out_ras_pear = r'C:\GeoNet\Pvalue\Send\Results\pearson_v01.TIF'
    out_ras_pval = r'C:\GeoNet\Pvalue\Send\Results\pvalue_v01.TIF'
    out_ras_mask = r'C:\GeoNet\Pvalue\Send\Results\mask_v01.TIF'
    # settings
    max_pval = 0.05
    min_corr = 0
    mask_val = 1
    no_mask_val = 0
    print "create nested numpy array list..."
    lst_np_ras = []
    for i in range(1, 5):
        ras_path1 = template1.format("%03d" % (i,))
        print " - ", ras_path1
        ras_np1 = arcpy.RasterToNumPyArray(ras_path1)
        ras_path2 = template2.format("%03d" % (i,))
        print " - ", ras_path2
        ras_np2 = arcpy.RasterToNumPyArray(ras_path2)
        lst_np_ras.append([ras_np1, ras_np2])
    print "read props numpy raster..."
    ras_np = lst_np_ras[0][0]  # take first numpy array from list
    rows = ras_np.shape[0]
    cols = ras_np.shape[1]
    print " - rows:", rows
    print " - cols:", cols
    print "create output numpy array..."
    ras_path = template1.format("%03d" % (1,))
    raster = arcpy.Raster(ras_path)
    ras_np_res_corr = np.ndarray((rows, cols))
    ras_np_res_pear = np.ndarray((rows, cols))
    ras_np_res_pval = np.ndarray((rows, cols))
    ras_np_res_mask = np.ndarray((rows, cols))
    print " - out rows:", ras_np_res_corr.shape[0]
    print " - out cols:", ras_np_res_corr.shape[1]
    print "loop through pixels..."
    pix_cnt = 0
    for row in range(rows):
        for col in range(cols):
            pix_cnt += 1
            if pix_cnt % 5000 == 0:
                print " - row:", row, "  col:", col, "  pixel:", pix_cnt
            lst_vals1 = []
            lst_vals2 = []
            try:
                for lst_pars in lst_np_ras:
                    lst_vals1.append(lst_pars[0][row, col])
                    lst_vals2.append(lst_pars[1][row, col])
                lst_vals1 = ReplaceNoData(lst_vals1, nodata)
                lst_vals2 = ReplaceNoData(lst_vals2, nodata)
                # perform calculation on list
                correlation = CalculateCorrelation(lst_vals1, lst_vals2, nodata)
                ras_np_res_corr[row, col] = correlation
                pearson = CalculatePearsons(lst_vals1, lst_vals2, nodata)
                ras_np_res_pear[row, col] = pearson
                pvalue = CalculatePvalue(lst_vals1, lst_vals2, nodata)
                ras_np_res_pval[row, col] = pvalue
                # compare correlation and p-value
                if pvalue == nodata:
                    mask = nodata
                elif (correlation >= min_corr) and (pvalue <= max_pval):
                    mask = mask_val
                else:
                    mask = no_mask_val
                ras_np_res_mask[row, col] = mask
            except Exception as e:
                print "ERR:", e
                print " - lst_vals1:", lst_vals1
                print " - lst_vals2:", lst_vals2
    pnt = arcpy.Point(raster.extent.XMin, raster.extent.YMin) #  - raster.meanCellHeight
    xcellsize = raster.meanCellWidth
    ycellsize = raster.meanCellHeight
    print "Write output rasters..."
    print " - ", out_ras_corr
    ras_res_corr = arcpy.NumPyArrayToRaster(ras_np_res_corr, lower_left_corner=pnt, x_cell_size=xcellsize,
                                 y_cell_size=ycellsize, value_to_nodata=nodata)
    arcpy.CopyRaster_management(ras_res_corr, out_ras_corr)
    arcpy.DefineProjection_management(in_dataset=out_ras_corr, coor_system="GEOGCS['GCS_WGS_1984',DATUM['D_WGS_1984',SPHEROID['WGS_1984',6378137.0,298.257223563]],PRIMEM['Greenwich',0.0],UNIT['Degree',0.0174532925199433]]")
    print " - ", out_ras_pear
    ras_res_pear = arcpy.NumPyArrayToRaster(ras_np_res_pear, lower_left_corner=pnt, x_cell_size=xcellsize,
    arcpy.CopyRaster_management(ras_res_pear, out_ras_pear)
    arcpy.DefineProjection_management(in_dataset=out_ras_pear, coor_system="GEOGCS['GCS_WGS_1984',DATUM['D_WGS_1984',SPHEROID['WGS_1984',6378137.0,298.257223563]],PRIMEM['Greenwich',0.0],UNIT['Degree',0.0174532925199433]]")
    print " - ", out_ras_pval
    ras_res_pval = arcpy.NumPyArrayToRaster(ras_np_res_pval, lower_left_corner=pnt, x_cell_size=xcellsize,
    arcpy.CopyRaster_management(ras_res_pval, out_ras_pval)
    arcpy.DefineProjection_management(in_dataset=out_ras_pval, coor_system="GEOGCS['GCS_WGS_1984',DATUM['D_WGS_1984',SPHEROID['WGS_1984',6378137.0,298.257223563]],PRIMEM['Greenwich',0.0],UNIT['Degree',0.0174532925199433]]")
    print " - ", out_ras_mask
    ras_res_mask = arcpy.NumPyArrayToRaster(ras_np_res_mask, lower_left_corner=pnt, x_cell_size=xcellsize,
    arcpy.CopyRaster_management(ras_res_mask, out_ras_mask)
    arcpy.DefineProjection_management(in_dataset=out_ras_mask, coor_system="GEOGCS['GCS_WGS_1984',DATUM['D_WGS_1984',SPHEROID['WGS_1984',6378137.0,298.257223563]],PRIMEM['Greenwich',0.0],UNIT['Degree',0.0174532925199433]]")
def CalculateCorrelation(a, b, nodata):
    import numpy
    try:
        coef = numpy.corrcoef(a,b)
        return coef[0][1]
    except:
        return nodata
def ReplaceNoData(lst, nodata):
    res = []
    for a in lst:
        if a < nodata / 2.0:
            res.append(None)
        else:
            res.append(a)
    return res
def CalculatePearsons(a, b, nodata):
    import numpy as np
    from scipy.stats import pearsonr
    try:
        x = np.array(a)
        y = np.array(b)
        r, p = pearsonr(a, y)
        return p
    except:
        return nodata
def CalculatePvalue(a, b, nodata):
    import numpy as np
    from scipy.stats import stats
    try:
        x = np.array(a)
        y = np.array(b)
        r, p_val = stats.pearsonr(x, y)
        return p_val
    except:
        return nodata
if __name__ == '__main__':
    main()
DanPatterson_Retired
Neither, p-value is a measure of the strength of the correlation coefficient calculated from sample size and the measured 'r' and a sampling distribution
scipy.stats.pearsonr — SciPy v1.3.0 Reference Guide
example for variants of simple arrays, using this
from scipy import stats
a = np.arange(9)
b = np.arange(9, 0, -1)
c = np.array([9, 7, 8, 6, 5, 4, 3, 2, 1]) # ---- like b, but 2 numbers switched
r, p_val = stats.pearsonr(a, b)  # ---- perfect inverse, r = -1, p = 0.0000
r, p_val
(-1.0, 0.0)
r, p_val = stats.pearsonr(a, c)
r, p_val
(-0.9833333333333333, 1.936196303745927e-06)
margaritastevia
New Contributor II
I want to extract the pixels where correlation is positive and p-value is < 0.05 How i can do that? How i can estimate P as a raster?
margaritastevia
New Contributor II
Hi Xander Bakker‌ please help me with how i can extract correlation values at 0.05 significance level. I'm running out of time.
XanderBakker
Hi margaritastevia
Can you share a sample of your data and the script you have so far?
margaritastevia
New Contributor II
Hi Xander Bakker,
Thank you very much for your kind response. please find the attachment.
XanderBakker
See code below:
def main():
    import arcpy
    import numpy as np
    # settings
    max_pval = 0.05
    min_corr = 0
    mask_val = 1
    no_mask_val = 0
    lst_np_ras = []
    pix_cnt = 0
            pix_cnt += 1
            lst_vals1 = []
            lst_vals2 = []
            try:
                    mask = nodata
                    mask = mask_val
                else:
                    mask = no_mask_val
                print "ERR:", e
    import numpy
    try:
        return coef[0][1]
    except:
        return nodata
    res = []
    for a in lst:
            res.append(None)
        else:
            res.append(a)
    return res
    import numpy as np
    try:
        x = np.array(a)
        y = np.array(b)
        return p
    except:
        return nodata
    import numpy as np
    try:
        x = np.array(a)
        y = np.array(b)
        return p_val
    except:
        return nodata
    main()
margaritastevia
New Contributor II
print("Thank you")
Thank you Sir Xander Bakker I'm vary thankful to you for your kind response. The script is running perfectly. Yes the pixels are near the river.
XanderBakker
Hi margaritastevia ,
Glad to hear that the script is producing the expected results. Good luck with you investigation!
YingyingZhang
Hi Xander Bakker,
    Glad to get the script of the correlation and P-value between rasters, but now I only have two rasters(ndvi and occurence of flooding). I can't  solve my question using the script above. I need calculate the correlation and p-value between two rasters not sets of rasters.Xander BakkerCalculate Correlation and P-value between rasters#My data is attached, need your help.
Best wishes
