I'm following an ESRI online learning tutorial: Creating Python Toolboxes Using ArcGIS 10.1.
I copy the script and test on my data but the new tool only recognises 'Street' as an input feature.
Can anyone tell me where is wrong with the codes below?
import arcpy
class Toolbox(object):
def __init__(self):
"""Define the toolbox (the name of the toolbox is the name of the
.pyt file)."""
self.label = "Calculate Geometry"
self.alias = "geometry"
self.tools = [CalculateGeometry]
class CalculateGeometry(object):
def __init__(self):
"""Define the tool (tool name is the name of the class)."""
self.label = "CalculateGeometry"
self.description = ""
self.canRunInBackground = True
def getParameterInfo(self):
"""Define parameter definitions"""
in_features = arcpy.Parameter(
displayName = 'Input Feature',
name = 'in_features',
datatype = 'Feature Layer',
parameterType = 'Required',
direction = 'Input')
in_features.filter.list = ['Point','Polyline','Polygon']
field = arcpy.Parameter(
displayName = 'Field name',
name = 'field_name',
datatype = 'Field',
field.parameterDependencies = [in_features.name]
in_features.filter.list = ['Short','Long','Double','Float','Text']
geomProperty = arcpy.Parameter(
displayName = 'Property',
name = 'geomProperty',
datatype = 'String',
units = arcpy.Parameter(
displayName = 'Units',
name = 'units',
parameterType = 'optional',
direction = 'Input',
enabled = False)
out_features = arcpy.Parameter(
displayName = 'Output Features',
name = 'out_features',
parameterType = 'Derived',
direction = 'Output')
out_features.schema.clone = True
params = [in_features, field, geomProperty, units, out_features]
return params
def isLicensed(self):
"""Set whether tool is licensed to execute."""
return True
def updateParameters(self, parameters):
"""Modify the values and properties of parameters before internal
validation is performed. This method is called whenever a parameter
has been changed."""
in_features = parameters[0]
geomProperty = parameters[2]
units = parameters[3]
pointPropertyList = ['X Coordinate of Point',
'Y Coordinate of Point']
linePropertyList = ['Length', 'X Coordinate of Line Start',
'Y Coordinate of Line Start',
'X Coordinate of Line End',
'Y Coordinate of Line End']
polygonPropertyList = ['Area','Perimeter',
'X Coordinate of Centroid',
'Y Coordinate of Centroid']
if in_features.value:
desc = arcpy.Describe(in_features.valueAsText)
if desc.shapeType == 'Point':
geomProperty.filter.list = pointPropertyList
elif desc.shapeType == 'Polyline':
geomProperty.filter.list = linePropertyList
elif desc.shapeType == 'Polygon':
geomProperty.filter.list = polygonPropertyList
areaUnitList = ['Acres','Ares','Hectares','Square Centimeters','Square Inches','Square Feet','Square Kilometers','Square Meters','Square Miles','Square Millimeters','Square Yard','Square Decimeters']
lengthUnitList = ['Centimeters','Feet','Inches','Kilometers','Meters','Miles','Millimeters','Nautical Miles','Yards','Decimal Degrees']
if geomProperty.value:
if geomProperty.valueAsText == 'Area':
units.enabled = True
units.filter.list = areaUnitList
elif geomProperty.valueAsText in ['Length','Perimeter']:
units.enabled =True
units.filter.list = lengthUnitList
else:
units.value = ''
units.filter.list = []
units.enabled = False
return
def updateMessages(self, parameters):
"""Modify the messages created by internal validation for each tool
parameter. This method is called after internal validation."""
geomProperty= parameters[2]
if desc.shapeType in ['Multipoint','Multipatch']:
in_features.setErrorMessage('{0} features are not supported.'.format(desc.shapeType))
if geomProperty.valueAsText in ['Length','Perimeter','Area']:
if not units.value:
units.setErrorMessage('Units required for {0} property'.format(geomProperty.valueAsText))
return
def execute(self, parameters, messages):
"""The source code of the tool."""
in_features = parameters[0].valueAsText
field = parameters[1].valueAsText
geomProperty= parameters[2].valueAsText
units = parameters[3].valueAsText
shapeFieldName = arcpy.Describe(in_features).shapeFieldName
exp = '!' + shapeFieldName
if geomProperty == 'Area':
exp += '.area@'+ units.replace('','')
elif geomProperty in ['Length','Perimeter']:
exp += '.length@'+ units.replace('','')
else:
propertyList = geomProperty.split('')
coord = propertyList[0]
if propertyList[-1] in ['Point','Start']:
exp += '.firstPoint.' + coord
elif propertyList[-1] == 'End':
exp += '.lastPoint.'+ coord
elif propertyList[-1] == 'Centroid':
exp += '.centroid.'+ coord
exp+= '!'
messages.addMessage(
'\nExpression used for field calculation: {0}\n'.format(exp))
arcpy.CalculateField_management(in_features,field,exp,'PYTHON_9.3')
return
