Calculating polyline azimuth - code error
8566
16
08-05-2014 01:43 AM
CamillaRootes
New Contributor III
Hi. I'm trying to run a Python script in the field calculator to output the azimuth values of a series of polylines. However, everytime I try to run the code it throws the following error:
"File "<string>", line 2, in GetAzimuthPolyline
AttributeError: 'str' object has no attribute 'x'
Failed to execute (CalculateField)."
The code block I am using is:
  1. import math
  2. def GetAzimuthPolyline(shape):
  3. radian = math.atan((shape.lastpoint.x - shape.firstpoint.x)/(shape.lastpoint.y - shape.firstpoint.y))
  4. degrees = radian * 180 / math.pi
  5. return degrees
I sourced the code from this thread Calculate angle of each line in a polyline shapefile‌. It seems to be working for the people in the thread but not for me. I'm running Arc 10.1 with the basic license, by the way.
Can anyone see where this is going wrong?
CamillaRootes
New Contributor III
Great, that's done it. Thanks to both of you for your help, much appreciated!
DavidHarbor
New Contributor III
Thanks for the postings, but I just tried this on an NHD dataset looking at the azimuths of stream polylines.  It doesn't return the correct azimuth  The azimuth -90 to 90 works, but between 90 and 270 degrees are incorrect. The streams flow direction is reversed.  I am going to look at the math, and will post if I see an improved answer.
DavidHarbor
New Contributor III
Here is some code that works for me, where the "answer" does not as shown in previous post.
def CalculaAzimuth(linea):
    if (hasattr(linea,'type') and linea.type == 'polyline'):
        xf = linea.firstPoint.X
        yf = linea.firstPoint.Y
        xl = linea.lastPoint.X
        yl = linea.lastPoint.Y
        dX = xl - xf
        dY = yl - yf
        PI = math.pi
        Azimuth = 0 #Default case, dX = 0 and dY >= 0
        if dX > 0:
            Azimuth = 90 - math.atan( dY / dX ) * 180 / PI
        elif dX < 0:
            Azimuth = 270 - math.atan( dY / dX )* 180 / PI
        elif dY < 0:
            Azimuth = 180
        return Azimuth
    else:
        return False
which comes from here
Syntax Errors when Calculating Azimuth with Python in Arcgis 10 - Stack Overflow
Wish I could make use of "atan2(y,x)" but I couldn't get it to return 0-360 correctly in all quadrants.
BruceHarold
Hi, try this:
#Function to return the north azimuth bearing of a line segment in degrees
def NorthAzimuth(x1,y1,x2,y2):
    degBearing = math.degrees(math.atan2((x2 - x1),(y2 - y1)))
    if (degBearing < 0):
        degBearing += 360.0
    return degBearing
DavidHarbor
New Contributor III
Two questions Bruce
why reverse the y and x  in the atan function?
what is the operator +=  ?
(sorry, I'm a python noob)
BruceHarold
To get north azimuth angles; try it:
>>> for x1y1x2y2 in [(0,0,1,1),(0,0,1,-1),(0,0,-1,-1),(0,0,-1,1)]:
...     x1,y1,x2,y2 = x1y1x2y2[0],x1y1x2y2[1],x1y1x2y2[2],x1y1x2y2[3]
...     print str(math.degrees(math.atan2((x2 - x1),(y2 - y1))))
45.0
135.0
-135.0
-45.0
The += is shorthand for degBearing = degBearing + 360.0
DavidHarbor
New Contributor III
Sweet. Thanks.
