Cannot delete... May be locked by another application.
17175
15
04-21-2014 04:52 PM
JohnLay
I've written a long script that selects a bunch of different feature classes and exports them to a file geodatabase by an attribute. Then I export those feature classes to shapefiles. Next, I zip the geodatabase into its own file and all the shapes into their own file. Finally, I delete the geodatabase and shapes so that all I'm left with is the 2 zip files (We do this for a FEMA product) in the output folder.
No problems.
Recently I learned that I needed to include several tables in the database as well, so I inserted some code that searches one table for an attribute and writes the output to a list. Then I use that list to query ANOTHER table to create a table in the database.
The problem is, now with this new bit of code, the geodatabase will not delete and I receive ExecuteError: ERROR 000601: Cannot delete C:\~Working\FRIS\Test2\Alamance\NCFlood_Prelim_Alamance_GDB.gdb. May be locked by another application. Failed to execute (Delete).
New bit of code:
# L_COMM_INFO
CIDList = []
S_POL_AR = os.path.join(FRIS_FGDB, "S_POL_AR")
S_POL_ARTable = arcpy.SearchCursor(S_POL_AR)
for ID in S_POL_ARTable:
    FIELD = "CID"
    Val = ID.getValue(FIELD)
    CIDList.append(Val)
NewCIDList = list(set(CIDList))
L_COMMUNITY_INFO = "Database Connections\NC_FLOOD.sde\NC_FLOOD.DBO.L_COMMUNITY_INFO"
L_COMMUNITY_INFOView = os.path.join(FRIS_FGDB, "L_COMM_INFOView")
L_COMMUNITY_INFOTable = os.path.join(FRIS_FGDB, "L_COMM_INFO")
arcpy.TableToTable_conversion (L_COMMUNITY_INFO, FRIS_FGDB, "L_COMM_INFO")
arcpy.TruncateTable_management (L_COMMUNITY_INFOTable)
arcpy.MakeTableView_management (L_COMMUNITY_INFO, L_COMMUNITY_INFOView)
for ITEM in NewCIDList:
    CLAUSE = ("{0} = '{1}'".format ("CID", ITEM))
    arcpy.SelectLayerByAttribute_management (L_COMMUNITY_INFOView, "NEW_SELECTION", CLAUSE)
    arcpy.Append_management (L_COMMUNITY_INFOView, L_COMMUNITY_INFOTable)
arcpy.Delete_management (L_COMMUNITY_INFOView, "")
del L_COMMUNITY_INFOTable
The delete code looks like this:
# Delete Files
Delete_Shapes = []
for shapefile in os.listdir(OUTPATH):
    if fnmatch.fnmatch(shapefile, '*.shp'):
        Delete_Shapes.append(shapefile)
    elif fnmatch.fnmatch(shapefile, '*.gdb'):
    else:
        pass
del shapefile
for shapefile in Delete_Shapes:
    get_file = os.path.join(OUTPATH, shapefile)
    arcpy.AddMessage("Deleting " + shapefile)
    arcpy.Delete_management(get_file)
The error occurs every time with the new code and never without.
When I use Unlocker.exe to unlock and delete the folder so that I can start all over again, I am told that RuntimeLocalServer.exe is the process locking the database.
What is wrong with the new bit of code that causes the RuntimeLocalServer lock? And how do I fix it?
NaimeCelik
Did anyone find a solution for how to delete locked shp files, I have same problem.. and very very frustrating...
JoshuaBixby
MVP Esteemed Contributor
It seems you are using the older/original search cursor instead of the newer data access (da) search cursor.  Have you tried using the da.SearchCursor with a Python with statement?  Does that change the result?
lelaharrington
New Contributor III
Did anyone get an answer to this. I am having the same issue however I am not using a search cursor at all I am using a delete  feature.. it is deleting one feature (DB2) and then moving feature 1 DB1 to DB2 where the previous feature was deleted. I keep getting this error as well. it makes no sense.
SugihonoBudiman
New Contributor II
To anyone looking for answer. Its a bug. See below
Synopsis
The arcpy.Delete_management (sde connection) function fails with the error, "000601: Cannot delete sde connection. May be locked by another application," in ArcMap 10.2.1.
Additional Information
N/A
Alternate Solution
Use os.remove() instead
NIM101220 - The arcpy.Delete_management (sde connection) funct..
AliNazari
New Contributor II
This is True.
I had to delete the .gdb where it was happening and recreate it to be able to solve the issue!
SugihonoBudiman
New Contributor II
No good. Any patch coming soon?
Thanks
Sugihono Budiman
Software Architect
• 917.873.5949
• sugihono.budiman@pcfcorp.com
Publishers Circulation Fulfillment, Inc.
www.pcfcorp.com
