Change text using arcpy
4959
10
08-11-2015 03:53 AM
Yaron_YosefCohen
Occasional Contributor II
Hi  there,
i try to change oldText with myString in 25 mxd's ( in the layout ).
The text (i used draw tool to create it) contain 2 row:
land use
fuel
myString is the new text
i try this code but python only print list of mxd names in the folder:
import arcpy
from arcpy import env
env.workspace = r"D:\PROJECTS\ab\gis"
counter = 0
for mxdname in arcpy.ListFiles("*.mxd"):
    print mxdname
    oldText = 'land use'
    oldText = oldText + '\n'
    oldText = oldText + 'fuel'
    mxd = arcpy.mapping.MapDocument(r"D:\PROJECTS\ab\gis\\" + mxdname)
    myString = 'free fuel'
    myString = myString + '\n'
    myString = myString + 'gas'
    for elm in arcpy.mapping.ListLayoutElements(mxd, "TEXT_ELEMENT"):
        if elm.text == oldText :
            print elm.name
            elm.text = myString
    mxd.save()
    counter = counter + 1
del mxd
is it possible with python 2.7.8?
thanks in advance.
Yaron_YosefCohen
thanks for everyone,
finally i use this code:
import arcpy
    print mxdname
        oldText = 'land use\nfuel'
        newText = u'free fuel\ngas'
        if elm.text == oldText:
            elm.text = newText
            print 'elm.text changed'
    mxd.save()
del mxd
DanPatterson_Retired
oldText = 'land use'  + '\n' + 'fuel'
myString = 'free fuel + '\n'  + 'gas'
show some output
it isn't a python issue
Yaron_YosefCohen
i get:
environment 1.mxd
environment 2.mxd
environment 3.mxd
til i get
environment 25.mxd
it only print mxd name
MichaelVolz
Esteemed Contributor
Print out the text elements without an if statement to ensure that your syntax for oldText is correct
do you actually print out oldtext?  all you print out is
print mxdname
ergo you get
environment 1.mxd
environment 2.mxd
environment 3.mxd
til i get
environment 25.mxd
put in print statements if you want to test stuff
LukeWebb
Occasional Contributor III
Basic python question here!, you just get the mxd names, as the if statement is never satisfied.
To resolve, try changing your code as follows, then you should be able to work out what has happened!
import arcpy
counter = 0
    print mxdname
    print "We are looking for a value of: "
    print oldText
            print elm.name
            elm.text = myString
        else:
            print "Non Matching Element value of:"
            print elm.text
    mxd.save()
del mxd
Yaron_YosefCohen
i try your code Luke and got result :
environment 1.mxd
land use
fuel
land use
fuel
environment 2.mxd
land use
fuel
the oldText still remain the same in the layout :
there is a couple of possibilities:
  • the words 'land' or 'use' might containing leading or trailing spaces
    • try "land " + "\nl" + "use"
    • or "land" + "\nl" + " use"
    • etc
  • what appears as one label stacked one over the other is actually two labels... one called land and the other called use  To confirm...try clicking on the label in the map and see if one or both words get highlighted
To elaborate consider the following examples (not all combinations checked):
>>> a = "land" + "\nl" + "use"
>>> a == a
True
>>> # now try some variations
>>> b = "land " + "\nl" + "use"  # extra space after 'land'
>>> a == b
False
>>> c = "land" + "\nl" + "use "  # extra space after 'use'
>>> a == c
False
>>> d = "land" + "use"
>>> a == d
False
Yaron_YosefCohen
i will try-thanks
